Ga door naar hoofdinhoud
Nikon Coolpix S9700 Back Panel Replacement
Matt Staubus
Matt Staubus en 3 andere bijdragers
Voor het laatst geüpdatet op August 16, 2020
5 - 15 minuten
Eenvoudig
Has some of the buttons on the S9700 become worn down from use? Do you have a large scratch on your screen? Both of these scenarios might require that you remove the back panel. The back panel gives you access most of the internal components and buttons of the S9700. It will take some time and patience, but once it is removed, every replacement you need to make will be possible!
Wat je nodig hebt
Gereedschap
  1. Nikon Coolpix S9700 Back Panel Replacement, Battery: stap 1, afbeelding 1 van 2 Nikon Coolpix S9700 Back Panel Replacement, Battery: stap 1, afbeelding 2 van 2
    • Press the ON/OFF button to power off the S9700.
    • Not doing so can damage the S9700 or cause electric shock.
  2. Nikon Coolpix S9700 Back Panel Replacement: stap 2, afbeelding 1 van 3 Nikon Coolpix S9700 Back Panel Replacement: stap 2, afbeelding 2 van 3 Nikon Coolpix S9700 Back Panel Replacement: stap 2, afbeelding 3 van 3
    • Place the S9700 upside down
    • Place your finger on the battery compartment cover and gently push toward the front of the S9700.
    • The cover will open up by itself.
  3. Nikon Coolpix S9700 Back Panel Replacement: stap 3, afbeelding 1 van 3 Nikon Coolpix S9700 Back Panel Replacement: stap 3, afbeelding 2 van 3 Nikon Coolpix S9700 Back Panel Replacement: stap 3, afbeelding 3 van 3
    • Push the yellow tab inside the battery compartment in the direction of the arrow. This will allow the battery to spring up.
  4. Nikon Coolpix S9700 Back Panel Replacement: stap 4, afbeelding 1 van 2 Nikon Coolpix S9700 Back Panel Replacement: stap 4, afbeelding 2 van 2
    • Grab the battery and pull out.
  5. Nikon Coolpix S9700 Back Panel Replacement, Back Panel: stap 5, afbeelding 1 van 2 Nikon Coolpix S9700 Back Panel Replacement, Back Panel: stap 5, afbeelding 2 van 2
    • Remove the two 4-mm and three 3-mm J000 screws from the bottom of the S9700.
    • Three 3-mm screws are on the side opposite the battery compartment.
    • Two 4-mm screws are on the side with the battery compartment. One of these screws is in the battery compartment. Open it up for access.
  6. Nikon Coolpix S9700 Back Panel Replacement: stap 6, afbeelding 1 van 2 Nikon Coolpix S9700 Back Panel Replacement: stap 6, afbeelding 2 van 2
    • Remove the one 3-mm J000 screw on the left side of the S9700 (side with no ports).
    • Remove the two 3-mm J000 screws on the right side (side with HDMI and charging ports).
    • One of these screws is underneath the HDMI port cover. Lift the port cover up to access.
  7. Nikon Coolpix S9700 Back Panel Replacement: stap 7, afbeelding 1 van 3 Nikon Coolpix S9700 Back Panel Replacement: stap 7, afbeelding 2 van 3 Nikon Coolpix S9700 Back Panel Replacement: stap 7, afbeelding 3 van 3
    • Insert the plastic opening tool on the bottom of the S9700 between the front panel and the back panel.
    • Twist the plastic opening tool so that both halves separate.
    • When both halves are separated, the HDMI cover, charging cover, and the ON/OFF switch will fall out.
    • There is a flex ribbon attached to the back panel. Forcing the back panel off may rip it.
  8. Nikon Coolpix S9700 Back Panel Replacement: stap 8, afbeelding 1 van 3 Nikon Coolpix S9700 Back Panel Replacement: stap 8, afbeelding 2 van 3 Nikon Coolpix S9700 Back Panel Replacement: stap 8, afbeelding 3 van 3
    • Remove the three silver 3-mm J000 screws on the back panel holding the silver button / dial component to the panel and ribbon.
    • Gently remove the back panel.
Conclusie
Matt Staubus
849 Reputatie
5 handleidingen geschreven
USF Tampa, Team 9-5, Lacy Fall 2016 Lid van USF Tampa, Team 9-5, Lacy Fall 2016
USFT-LACY-F16S9G5
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 1,201
