Ga door naar hoofdinhoud
Nikon Coolpix S30 LCD Screen Replacement
Cassie Hamm
Cassie Hamm en 5 andere bijdragers
Voor het laatst geüpdatet op May 7, 2024
10 - 15 minuten
Gemiddeld
For this guide you will need a new LCD screen. If you are using iFixit tools, you will need a PH000 head and a T5 star head.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Nikon Coolpix S30 LCD Screen Replacement, Batteries: stap 1, afbeelding 1 van 2 Nikon Coolpix S30 LCD Screen Replacement, Batteries: stap 1, afbeelding 2 van 2
    • Slide the battery cover to the right.
    • The hinge is on the left side of the cover which will allow the cover to stay attached.
  2. Nikon Coolpix S30 LCD Screen Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix S30 LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
  3. Nikon Coolpix S30 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the batteries by gently tipping the camera.
  4. Nikon Coolpix S30 LCD Screen Replacement, LCD Screen: stap 4, afbeelding 1 van 1
    • FIRST: remove the batteries.
    • Unscrew the four screws around the corners of the camera. This can be done using the iFixit kit's T5 (star tip screwdriver)
  5. Nikon Coolpix S30 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the screw on the left (silver) first. It can be removed with the same tip (T5)
    • Change screwdriver tip to iFixit kit's PH000. This removes the screw on the right (black) It is a small Phillips head.
  6. Nikon Coolpix S30 LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Gently separate the back panel from the rest of the camera.
  7. Nikon Coolpix S30 LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove screw connecting the top right of the screen to the mother board.
  8. Nikon Coolpix S30 LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Spin the camera around and gently pull the screen towards you. This will allow easy access to components on the motherboard.
  9. Nikon Coolpix S30 LCD Screen Replacement: stap 9, afbeelding 1 van 2 Nikon Coolpix S30 LCD Screen Replacement: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Remove connected strip by flipping up the small off-white plastic strip with tweezers.
    • Gently pull out the strip from the motherboard.
  10. Nikon Coolpix S30 LCD Screen Replacement: stap 10, afbeelding 1 van 2 Nikon Coolpix S30 LCD Screen Replacement: stap 10, afbeelding 2 van 2
    • Remove screw that is now in the top right corner. This will detach the screen entirely.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cassie Hamm
207 Reputatie
2 handleidingen geschreven
Penn State, Team 2-4, Kaschak Winter 2015 Lid van Penn State, Team 2-4, Kaschak Winter 2015
PSU-KASCHAK-W15S2G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 953
