Ga door naar hoofdinhoud
Nikon Coolpix AW130 LCD Screen Replacement
Lauren Stepp
Lauren Stepp en 2 andere bijdragers
Voor het laatst geüpdatet op May 7, 2024
40 minuten
Moeilijk
Without the LCD screen, you cannot preview your nifty vacation photos. If this screen is cracked, the waterproof qualities of the Nikon may be sacrificed. Allowing water to infiltrate into the body can cause for additional problems.
Wat je nodig hebt
Gereedschap
  1. Nikon Coolpix AW130 LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 2 Nikon Coolpix AW130 LCD Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 LCD Screen Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix AW130 LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 LCD Screen Replacement: stap 4, afbeelding 1 van 2 Nikon Coolpix AW130 LCD Screen Replacement: stap 4, afbeelding 2 van 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: stap 5, afbeelding 1 van 2 Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: stap 5, afbeelding 2 van 2
    • Using the T5 Torx screwdriver, remove all four 4mm screws.
  6. Nikon Coolpix AW130 LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
  7. Nikon Coolpix AW130 LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove the upper cover (connected by glue) and unscrew the single Philips screw.
  8. Nikon Coolpix AW130 LCD Screen Replacement: stap 8, afbeelding 1 van 2 Nikon Coolpix AW130 LCD Screen Replacement: stap 8, afbeelding 2 van 2
    • Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
  9. Nikon Coolpix AW130 LCD Screen Replacement: stap 9, afbeelding 1 van 1
    • Carefully remove the back cover from the camera body.
  10. Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: stap 10, afbeelding 1 van 3 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: stap 10, afbeelding 2 van 3 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: stap 10, afbeelding 3 van 3
    • Using a Phillips #000 screwdriver, remove all 11, 4mm screws on the LCD screen cover.
    • Two screws are located on the right.
    • The remaining screws are hidden behind a connector ribbon on the left.
  11. Nikon Coolpix AW130 LCD Screen Replacement: stap 11, afbeelding 1 van 2 Nikon Coolpix AW130 LCD Screen Replacement: stap 11, afbeelding 2 van 2
    • Pull the LCD screen from the plastic frame after removing all of the screws.
  12. Nikon Coolpix AW130 LCD Screen Replacement: stap 12, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using a pair of tweezers from the precision tweezer set, carefully remove the screen from the metal frame.
    • Since the tweezers could shatter the screen, causing for broken glass, exercise extreme caution.
Conclusie
Lauren Stepp
1.251 Reputatie
8 handleidingen geschreven
8 opmerkingen
Hi.
Where can you buy a replacement screen?
Ben - Antwoord
Hi.
my contact is josem6073@gmail.com
Thank you .
Jose Martins - Antwoord
Please add Torx T5 screwdriver at the tool needed, required at step 5
macreateur - Antwoord
Hi.
my contact is cpapacon@gmail.com
Thank you .
Costis Papaconstantinou - Antwoord
Hi.
my contact is Keithdurkan@gmail.com
Thank you .
Keith Durkan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 3,131
