Ga door naar hoofdinhoud
Nikon Coolpix AW130 Battery Replacement
Lauren Stepp
Lauren Stepp en een andere bijdrager
Voor het laatst geüpdatet op June 16, 2020
5 minuten
Zeer eenvoudig
Uitgelichte studenten-handleiding
Removing the battery is a necessary prerequisite step in all Nikon Coolpix AW130 repairs. Failing to complete this step prior to replacing the LED screen or shutter button, for example, may result in electrical shock. No tools are required.
  1. Nikon Coolpix AW130 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Nikon Coolpix AW130 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Battery Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix AW130 Battery Replacement: stap 2, afbeelding 2 van 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Battery Replacement: stap 3, afbeelding 1 van 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Battery Replacement: stap 4, afbeelding 1 van 2 Nikon Coolpix AW130 Battery Replacement: stap 4, afbeelding 2 van 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
Conclusie
Lauren Stepp
1.251 Reputatie
8 handleidingen geschreven
Één opmerking
Try the following before ordering your battery :
The problem with my cool pix aw130 was the little yellow plastic tab ( seen in one of the above photos ; step 3 ) that supposed to keep the battery shoved tightly against the terminals . In time , it wears and the battery no longer makes contact ; hence never getting recharged . The fix is simple ! Cut a 1/4” x 1/4” piece of paper , cardboard , or plastic , and wedge it between the yellow tab and the battery . Then recharge , as before .
Franklin Noel Stein - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 16
Altijd: 2,613
