Motorola Droid Rear Case Replacement
Inleiding
Ga naar stap 1This guide will take you through the delicate process of removing the rear panel of the Motorola Droid.
Wat je nodig hebt
Gereedschap
Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
Lift and remove the battery cover out from the phone.
Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
6 andere personen hebben deze handleiding voltooid.
