Motorola Droid MAXX 2 Screen Only Replacement
Wat je nodig hebt
Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
Remove the static tape covering the two connectors.
Use a spudger to disconnect the battery cables from the motherboard.
If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
Gereedschap gebruikt in deze stap:Tweezers$4.99
We will be removing these 3 ribbon cables.
Using an opening pick, lift the grey tab on the rear camera's ZIF connector. Remove the ribbon cable and the camera.
Use tweezers to lift up on the grey latch on the ZIF connector.
Remove the ribbon cable from the ZIF connector.
Use an opening pick or metal jimmy to carefully peel up a corner of this section of copper tape.
Slowly peel the entire piece of copper tape off of the frame, trying not to tear or kink it. Set aside and re-install after attaching new display.
Using the pointy tip of a spudger, detach these display cable tabs from the frame.
