Ga door naar hoofdinhoud
Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement
Wat je nodig hebt
  1. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Prepare your laptop for disassembly: stap 1, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Prepare your laptop for disassembly: stap 1, afbeelding 2 van 2
    • Allow your laptop's battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Flip the laptop over: stap 2, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Flip the laptop over: stap 2, afbeelding 2 van 2
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  3. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Feet removal information: stap 3, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Feet removal information: stap 3, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Feet removal information: stap 3, afbeelding 3 van 3
    • Each foot has a recess to help pry it from the laptop:
    • The back feet recesses are closest to the back edge of the laptop.
    • The front feet recesses are closest to the front edge of the laptop.
  4. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the feet: stap 4, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the feet: stap 4, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the feet: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Insert one arm of your tweezers into the recess of one of the feet.
    • Twist your tweezers and pry up to separate the adhesive and unclip the foot from the laptop.
    • The feet eject very quickly—be careful not to lose them.
    • Remove the foot.
    • Repeat this process on the remaining feet.
  5. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Reassembly information: stap 5, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Reassembly information: stap 5, afbeelding 2 van 2
    Tesa 61395 Tape
    $5.99
    Koop
    • This laptop has two different types of feet. During reassembly, make sure the feet go in their correct recesses.
    • The rear feet have a single center clip.
    • The front feet have three clips and can only be reinserted one way.
    • Press the feet into their recesses to secure them to the frame.
    • If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
  6. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement: stap 6, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement: stap 6, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement: stap 6, afbeelding 3 van 3
    • If the feet are damaged or worn out, use 8 mm rubber furniture pads:
    • Peel a pad away from its backing.
    • Align the pad over a foot cavity and press down to secure it.
  7. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Unfasten the upper case: stap 7, afbeelding 1 van 1
    FixMat
    $36.95
    Koop
    • These screws strip easily. Apply constant, downward force to prevent stripping.
    • Use a T5 Torx driver to remove the four 3 mm screws securing the upper case.
  8. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Open the screen: stap 8, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Open the screen: stap 8, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Open the screen: stap 8, afbeelding 3 van 3
    • Flip your laptop over and fully open the screen.
  9. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Lift the upper case: stap 9, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Lift the upper case: stap 9, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Lift the upper case: stap 9, afbeelding 3 van 3
    • The upper case is secured by magnets.
    • Grip the top edge of the upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case, as it's still connected to the laptop by a cable.
    • Lift the bottom edge of the upper case up and away from the laptop, taking care to not strain the ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the screen could damage the screen as it closes.
  10. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the keyboard and touchpad cable: stap 10, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the keyboard and touchpad cable: stap 10, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the keyboard and touchpad cable: stap 10, afbeelding 3 van 3
    • The keyboard and touchpad cable connects the upper case to the laptop.
    • Insert the pointed end of a spudger under one edge of the magnet connector and pry up to disconnect it.
    • To reconnect the cable, align the magnet connector over its socket with the cable facing the bottom of the laptop. Press down on the connector to secure it.
  11. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the upper case: stap 11, afbeelding 1 van 1
    • Remove the upper case and set it keyboard-side down on a clean surface.
  12. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Reassembly information: stap 12, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Reassembly information: stap 12, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Reassembly information: stap 12, afbeelding 3 van 3
    Microfiber Cleaning Cloths
    $3.99
    Koop
    • Your SSD has thermal paste that forms a bond to the upper case.
    • During reassembly:
    • Use the flat end of your spudger to scrape away old thermal paste from the top of the SSD and the underside of the upper case.
    • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the SSD and upper case. Wipe away the residue using a lint-free or microfiber cloth.
    • Replace the thermal pad with one that's the same size as the SSD sticker.
    • Alternatively, you can apply a bead of thermal paste directly to the SSD's label. Use the dot method with a bead slightly larger than the screw head securing the SSD.
  13. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Unfasten the SSD: stap 13, afbeelding 1 van 1
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • With the screw removed, the SSD pops up at a shallow angle.
  14. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the SSD: stap 14, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the SSD: stap 14, afbeelding 2 van 2
    • Removing the SSD also functions as a battery disconnect.
    • Pull the SSD out of its socket and remove it.
    • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
    • During reassembly, insert the SSD at a slight angle.
  15. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the heatsink shield tape: stap 15, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the heatsink shield tape: stap 15, afbeelding 2 van 2
    Koop
    • Conductive tape attaches the left edge of the heatsink shield to the heatsink.
    • Heat the tape with a heat gun or hair dryer to soften its adhesive.
    • Use tweezers or your fingers to remove the tape.
    • During reassembly, apply the tape in the same location it came from. Reheat the adhesive if the tape doesn’t stick well to the heatsink at first.
  16. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Unclip the heatsink shield: stap 16, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Unclip the heatsink shield: stap 16, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Unclip the heatsink shield: stap 16, afbeelding 3 van 3
    Koop
    • Try not to deform the shield too much. You'll need to reinstall it during reassembly.
    • Insert the pointed end of a spudger in one of the gaps on the top edge of the heatsink shield.
    • Gently pry up to release the clips securing the shield.
    • Repeat this process along the right edge.
    • Insert one arm of your tweezers under the bottom right edge of the heatsink shield.
    • Gently pry up to release the remaining clips.
  17. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the heatsink shield: stap 17, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the heatsink shield: stap 17, afbeelding 2 van 2
    • Remove the heatsink shield.
    • To reinstall a shield, press down around its perimeter to engage the shield clips.
  18. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the fan: stap 18, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the fan: stap 18, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the fan: stap 18, afbeelding 3 van 3
    • Use the pointed end of a spudger to flip up the locking flap on the fan cable ZIF connector.
    • Grip the fan cable pull-tab with tweezers and pull the cable straight out of the connector.
  19. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Unfasten the heatsink: stap 19, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Unfasten the heatsink: stap 19, afbeelding 2 van 2
    • Use a T3 Torx driver to remove the nine screws securing the heatsink:
    • Two 2.5 mm screws
    • Two 2 mm screws
    • One 3 mm screw
    • Two 4.1 mm screws
    • Two 3.4 mm screws
  20. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Reassembly information: stap 20, afbeelding 1 van 1
    • Align the heatsink with the centering peg on the motherboard.
    • Tighten the four CPU tension screws in an "X" pattern: top left, bottom right, top right, bottom left.
  21. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Pry up the heatsink: stap 21, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Pry up the heatsink: stap 21, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Pry up the heatsink: stap 21, afbeelding 3 van 3
    • Thermal paste bonds the heatsink to the CPU.
    • Insert your spudger under the left heat pipe.
    • Pry up to release the left section of the heatsink.
    • This may take some force. Be careful not to bend the heat pipes.
    • Repeat this procedure for the right heat pipe and the CPU screw mounts until the heatsink is completely separated from the motherboard.
  22. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the heatsink: stap 22, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the heatsink: stap 22, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the heatsink: stap 22, afbeelding 3 van 3
    • Lift the heatsink and fan over the alignment peg in the upper right corner.
    • Slide the heatsink and fan toward the front edge of the laptop and remove it.
  23. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Reapply thermal paste: stap 23, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Reapply thermal paste: stap 23, afbeelding 2 van 2
    • Before reinstalling the heatsink, follow this guide to clean the heatsink and CPU and reapply thermal paste.
  24. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the display cable shields: stap 24, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the display cable shields: stap 24, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the display cable shields: stap 24, afbeelding 3 van 3
    Koop
    • Insert one arm of your tweezers under the corner of the left display cable shield.
    • Repeat this process around the perimeter of the shield until you can remove it.
  25. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement: stap 25, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement: stap 25, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement: stap 25, afbeelding 3 van 3
    • Pull the left display cable shield way from the screen to free it from its recess.
    • Remove the shield.
  26. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement: stap 26, afbeelding 1 van 1
  27. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Unclip the left motherboard shield: stap 27, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Unclip the left motherboard shield: stap 27, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Unclip the left motherboard shield: stap 27, afbeelding 3 van 3
    • Some motherboard screws are located under two of the metal shields, both of which need to be removed.
    • Insert one arm of your tweezers under the corner of the left touchpad shield.
  28. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the left motherboard shield: stap 28, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the left motherboard shield: stap 28, afbeelding 2 van 2
    • Remove the left motherboard shield.
  29. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Clean and reapply thermal paste: stap 29, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Clean and reapply thermal paste: stap 29, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Clean and reapply thermal paste: stap 29, afbeelding 3 van 3
    • There may be thermal paste between the motherboard and its left shield.
    • Before reinstalling the left motherboard shield, follow this guide to clean and reapply thermal paste.
  30. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the right motherboard shield: stap 30, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the right motherboard shield: stap 30, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the right motherboard shield: stap 30, afbeelding 3 van 3
    • Insert one arm of your tweezers under the corner of the right motherboard shield and pry around its perimeter up to release the clips.
    • Remove the right motherboard shield.
  31. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Reassembly information: stap 31, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Reassembly information: stap 31, afbeelding 2 van 2
    • During reassembly, use the flat end of a spudger to gently push the display cables back into their cavity in the lower case after reconnecting the press connectors.
  32. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the display cables: stap 32, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the display cables: stap 32, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the display cables: stap 32, afbeelding 3 van 3
    • Use the flat end of a spudger to pry up and disconnect all four display cable press connectors.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  33. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the right speaker: stap 33, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the right speaker: stap 33, afbeelding 2 van 2
    • Use the pointed end of a spudger to lift and disconnect the right speaker wire from its connector on the motherboard.
  34. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the Surface Connect port: stap 34, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the Surface Connect port: stap 34, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the Surface Connect port: stap 34, afbeelding 3 van 3
    • Use the flat end of a spudger to flip open the locking arm on the Surface Connect port connector.
    • Grip the Surface Connect port cable and pull it straight out of its socket.
  35. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the left speaker: stap 35, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the left speaker: stap 35, afbeelding 2 van 2
    • Use the pointed end of a spudger to lift and disconnect the left speaker wire from its connector near the left ports.
  36. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the black antenna cable: stap 36, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Disconnect the black antenna cable: stap 36, afbeelding 2 van 2
    • Slide one arm of your tweezers under the black antenna connector, as close to the head as possible.
    • Lift straight up to disconnect the cable.
    • To reattach antenna connectors, align the head of the connector over its socket and press down with the flat end of a spudger. The connector will snap into place.
  37. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Unfasten the motherboard bracket: stap 37, afbeelding 1 van 1
    • Use a T3 Torx driver to remove the two 3 mm screws securing the motherboard bracket.
  38. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the motherboard bracket: stap 38, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the motherboard bracket: stap 38, afbeelding 2 van 2
    • Remove the motherboard bracket.
  39. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Unfasten the left port cover: stap 39, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Unfasten the left port cover: stap 39, afbeelding 2 van 2
    • Use a T3 Torx driver to remove the three 2.1 mm screws securing the left port cover.
  40. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the left port cover: stap 40, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the left port cover: stap 40, afbeelding 2 van 2
    • Remove the left port cover.
  41. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Unfasten the motherboard: stap 41, afbeelding 1 van 2 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Unfasten the motherboard: stap 41, afbeelding 2 van 2
    • Use a T3 Torx driver to remove the six 2 mm screws securing the motherboard.
    • If any of your screws have rubber covers, peel and remove them.
  42. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Lift the right edge: stap 42, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Lift the right edge: stap 42, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Lift the right edge: stap 42, afbeelding 3 van 3
    • The left edge of the motherboard is held tight by the port cutouts, the speaker, and the frame.
    • Lift the right edge of the motherboard slightly over the battery.
    • Hold the motherboard in place while you follow the step to free the left edge.
  43. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Pry the left edge: stap 43, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Pry the left edge: stap 43, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Pry the left edge: stap 43, afbeelding 3 van 3
    • A tab on the upper left of the motherboard presses against protrusions in the frame, preventing the left edge from coming free.
    • Insert the tip of a spudger against the tab in the upper left corner of the motherboard. Wedge the spudger between the frame and the screen hinge.
    • Pry up on the tab with your spudger while you lift the right edge of the motherboard toward the front of the laptop.
    • If the motherboard can't lift over the left speaker, the tab may still be stuck. Change the angle of your spudger and try again.
  44. Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the motherboard: stap 44, afbeelding 1 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the motherboard: stap 44, afbeelding 2 van 3 Microsoft Surface Laptop 5 (13.5-inch) Motherboard Replacement, Remove the motherboard: stap 44, afbeelding 3 van 3
    • Remove the motherboard.
    • Ensure the two screwpost braces underneath the motherboard don't get lost during removal.
    • Make sure none of the eight cables get trapped underneath.
    • Position the left ports in their recess before sliding the motherboard into place.
Conclusie
Clay Eickemeyer
68.002 Reputatie
453 handleidingen geschreven
iFixit Lid van iFixit
Staff
137 Leden
17.523 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 47
Altijd: 353
