Ga door naar hoofdinhoud
Microsoft Surface Book Screen Replacement
Wat je nodig hebt
  1. Microsoft Surface Book Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Heat an iOpener and lay it on the bottom edge of the screen to soften the glue securing it.
    • You can also use a hair dryer or heat gun, but be careful as extreme heat can damage the screen and/or battery.
    Vraag FixBot
    Voeg opmerking toe
  2. Microsoft Surface Book Screen Replacement, Anti-Clamp instructions: stap 2, afbeelding 1 van 3 Microsoft Surface Book Screen Replacement, Anti-Clamp instructions: stap 2, afbeelding 2 van 3 Microsoft Surface Book Screen Replacement, Anti-Clamp instructions: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your Surface Book so it rests level between the suction cups.
    • Position the suction cups near the middle of the bottom edge—one on the front, and one on the back.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
    Vraag FixBot
    Voeg opmerking toe
  3. Microsoft Surface Book Screen Replacement: stap 3, afbeelding 1 van 3 Microsoft Surface Book Screen Replacement: stap 3, afbeelding 2 van 3 Microsoft Surface Book Screen Replacement: stap 3, afbeelding 3 van 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Vraag FixBot
    Voeg opmerking toe
  4. Microsoft Surface Book Screen Replacement: stap 4, afbeelding 1 van 3 Microsoft Surface Book Screen Replacement: stap 4, afbeelding 2 van 3 Microsoft Surface Book Screen Replacement: stap 4, afbeelding 3 van 3
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the bottom edge.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
    Vraag FixBot
    Voeg opmerking toe
  5. Microsoft Surface Book Screen Replacement, Insert an opening pick: stap 5, afbeelding 1 van 3 Microsoft Surface Book Screen Replacement, Insert an opening pick: stap 5, afbeelding 2 van 3 Microsoft Surface Book Screen Replacement, Insert an opening pick: stap 5, afbeelding 3 van 3
    • The adhesive securing the screen is very strong. This step may take significant force and multiple attempts.
    • Apply a suction handle to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
    Vraag FixBot
    Voeg opmerking toe
  6. Microsoft Surface Book Screen Replacement: stap 6, afbeelding 1 van 2 Microsoft Surface Book Screen Replacement: stap 6, afbeelding 2 van 2
    • Use the pick to slice all the way around the perimeter of the screen to separate the glue.
    • Do not insert the opening pick too far into the screen or you may cause damage to internal components.
    • Gently raise the screen but don't fully detach it until the cables underneath are disconnected.
    Vraag FixBot
    Voeg opmerking toe
  7. Microsoft Surface Book Screen Replacement: stap 7, afbeelding 1 van 3 Microsoft Surface Book Screen Replacement: stap 7, afbeelding 2 van 3 Microsoft Surface Book Screen Replacement: stap 7, afbeelding 3 van 3
    • Begin by removing the ribbon on the right. With the curved tweezers, carefully remove the metal bracket to expose the end of the ribbon. Remove ribbon.
    Vraag FixBot
    Voeg opmerking toe
  8. Microsoft Surface Book Screen Replacement: stap 8, afbeelding 1 van 3 Microsoft Surface Book Screen Replacement: stap 8, afbeelding 2 van 3 Microsoft Surface Book Screen Replacement: stap 8, afbeelding 3 van 3
    • Next, remove the metal shield covering the other ribbon. Then remove the ribbon.
    • Remove the screen.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
28 andere personen hebben deze handleiding voltooid.
Wesley Kendrick
2.339 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-6, Sullivan Spring 2017 Lid van USF Tampa, Team 1-6, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G6
3 Leden
14 handleidingen geschreven
34Gids Commentaar
It is very unlikely you will get this screen off without breaking it. Luckily, my customer only wanted the SSD out of the device so he didn't care if I damaged it. This screen is crazy fragile and the glue is very very strong. Do not do this job thinking you will likely not break the screen, unless you have done it before.
Kevin Yaniak - Antwoord Deel
The only way to remove it without breaking it is to use good scotch tape and completely cover the screen with a minimum 4 layers of tape. This will keep the screen intact - but you still have to be very careful.
Michael Griffiths - Antwoord Deel
That’s definitely not the only way. I just did it with a guitar pick and heat pad. After doing a ton of Surface Pro 3’s, I think this one is actually pretty easy in comparison.
austin - Antwoord Deel
I needed 3 hours for this, Did this the first time. There is everything glued. and real hard to not break the screen.
Dennis Reimer - Antwoord Deel
Can you put the screen back on after removing it?
Alex Shinnerl - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 72
Afgelopen 30 dagen: 270
Altijd: 61,592
