Ga door naar hoofdinhoud
Meta Quest 2 Controller Ring Shell Replacement
Wat je nodig hebt
  1. Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: stap 1, afbeelding 1 van 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: stap 1, afbeelding 2 van 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: stap 1, afbeelding 3 van 3
    • Use your fingers to slide the battery cover down towards the strap end of the controller.
    • Remove the battery cover.
    • If you're taking the controller apart for repairs, remove the batteries in the controller.
    Vraag FixBot
    Voeg opmerking toe
  2. Meta Quest 2 Controller Ring Shell Replacement, Remove the wrist strap: stap 2, afbeelding 1 van 2 Meta Quest 2 Controller Ring Shell Replacement, Remove the wrist strap: stap 2, afbeelding 2 van 2
    • Use your fingers to grasp the wrist strap near the anchor peg.
    • Lift the wrist strap anchor peg straight out of its recess.
    • Remove the wrist strap.
    Vraag FixBot
    Voeg opmerking toe
  3. Meta Quest 2 Controller Ring Shell Replacement, Loosen the faceplate adhesive: stap 3, afbeelding 1 van 1
    • Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
    Vraag FixBot
    Voeg opmerking toe
  4. Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: stap 4, afbeelding 1 van 3 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: stap 4, afbeelding 2 van 3 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: stap 4, afbeelding 3 van 3
    • The controller faceplate is secured with adhesive and three friction pegs.
    • Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
    • If you can’t get the opening tool into the seam, heat the area with an iOpener for a minute and try again.
    • Slide the opening tool to the base of the ring shell to loosen the adhesive.
    Vraag FixBot
    Voeg opmerking toe
  5. Meta Quest 2 Controller Ring Shell Replacement: stap 5, afbeelding 1 van 2 Meta Quest 2 Controller Ring Shell Replacement: stap 5, afbeelding 2 van 2
    • Use an opening tool to pry up on the seam to loosen the first friction peg.
    Vraag FixBot
    Voeg opmerking toe
  6. Meta Quest 2 Controller Ring Shell Replacement: stap 6, afbeelding 1 van 2 Meta Quest 2 Controller Ring Shell Replacement: stap 6, afbeelding 2 van 2
    • Continue prying around the entire faceplate to separate the remaining friction pegs and adhesive.
    • If you're having trouble, apply a heated iOpener to the faceplate for a minute and try again.
    Vraag FixBot
    Voeg opmerking toe
  7. Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: stap 7, afbeelding 1 van 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: stap 7, afbeelding 2 van 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: stap 7, afbeelding 3 van 3
    • Remove the controller faceplate.
    • The three friction pegs should hold the faceplate securely, so you don’t need to replace the adhesive during reassembly. Be sure to firmly press the faceplate onto the controller so that all friction pegs fully engage.
    Vraag FixBot
    Voeg opmerking toe
  8. Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller ring shell: stap 8, afbeelding 1 van 2 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller ring shell: stap 8, afbeelding 2 van 2
    • Use a Torx T5 driver to remove the four screws securing the controller ring shell to the controller:
    • Two 4.7 mm‑long screws
    • Two 5.9 mm‑long screws
    Vraag FixBot
    Voeg opmerking toe
  9. Meta Quest 2 Controller Ring Shell Replacement: stap 9, afbeelding 1 van 2 Meta Quest 2 Controller Ring Shell Replacement: stap 9, afbeelding 2 van 2
    • Press the point of a spudger firmly against the white alignment square to release the ring shell.
    Vraag FixBot
    Voeg opmerking toe
  10. Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: stap 10, afbeelding 1 van 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: stap 10, afbeelding 2 van 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: stap 10, afbeelding 3 van 3
    • Use your fingers to grab the end of the ring shell that doesn’t have the white alignment square.
    • Gently lift the ring shell up and away from the controller to unclip it from the controller.
    • Remove the controller ring shell.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Arthur Shi
337.774 Reputatie
851 handleidingen geschreven
iFixit Lid van iFixit
Staff
122 Leden
26.572 handleidingen geschreven
1Gids Commentaar
This Tutorial was really fast and easy also, I fixed my controller and it works very well now, Thank you!
# “‪Diamond‬” # - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 162
Altijd: 7,432
