Ga door naar hoofdinhoud
MacBook Unibody Model A1342 Rear Vent Replacement
Walter Galan
Walter Galan en 5 andere bijdragers
Voor het laatst geüpdatet op November 2, 2021
15 minuten
Gemiddeld
Use this guide to remove the cast aluminum rear vent from your MacBook.
Wat je nodig hebt
Onderdelen
Gereedschap
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  • TR8 Torx Security Screwdriver
Toon meer…
  1. MacBook Unibody Model A1342 Rear Vent Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Rear Vent Replacement: stap 2, afbeelding 1 van 3 MacBook Unibody Model A1342 Rear Vent Replacement: stap 2, afbeelding 2 van 3 MacBook Unibody Model A1342 Rear Vent Replacement: stap 2, afbeelding 3 van 3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
  3. MacBook Unibody Model A1342 Rear Vent Replacement, Battery: stap 3, afbeelding 1 van 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • It may be easier to use your fingernails to lift up on both sides of the connector.
  4. MacBook Unibody Model A1342 Rear Vent Replacement, Rear Vent: stap 4, afbeelding 1 van 1
    • Remove the following screws from the optical drive side of the rear vent:
    • Two 10 mm T8 Torx
    • Two 5.2 mm Phillips
  5. MacBook Unibody Model A1342 Rear Vent Replacement: stap 5, afbeelding 1 van 1
    • Remove the following screws from the port side of rear vent:
    • Two 10 mm T8 Torx
  6. MacBook Unibody Model A1342 Rear Vent Replacement: stap 6, afbeelding 1 van 1
    • Carefully lift the rear vent out of the upper case.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Één opmerking
Wow.....i fix it my speaker problem
NAVEEN Justin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 21
Altijd: 11,715
