Ga door naar hoofdinhoud
MacBook Unibody Model A1342 Lower Case Replacement
Walter Galan
Walter Galan en 7 andere bijdragers
Voor het laatst geüpdatet op August 13, 2019
30 seconden - 5 minuten
Eenvoudig
Replacing your lower case is easy! It only takes 8 screws.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. MacBook Unibody Model A1342 Lower Case Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Lower Case Replacement: stap 2, afbeelding 1 van 3 MacBook Unibody Model A1342 Lower Case Replacement: stap 2, afbeelding 2 van 3 MacBook Unibody Model A1342 Lower Case Replacement: stap 2, afbeelding 3 van 3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
Conclusie
74 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Apple has a recall on this part, so you can get a replacement for an improved version free and save yourself $149.99. Check out http://www.apple.com/support/macbook-bot...
Shane - Antwoord
Would the Macbook Pro back cover also fit this?
wow - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 50
Altijd: 70,232
