Inleiding
Follow this guide to remove your trackpad—either to replace it, or to get it out of the way so you can access the battery.
For your safety, discharge your MacBook Pro's battery below 25% before you start. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured.
Gereedschap
Power on your Mac and launch Terminal.
Copy and paste the following command (or type it exactly) into Terminal:
sudo nvram AutoBoot=%00
Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
sudo nvram AutoBoot=%03
Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
Four 4.7 mm screws
Two 6.6 mm screws
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips. You should feel and hear them click into place.
Peel up and remove the large rectangular battery board cover, on the edge of the logic board nearest the battery.
If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
Use a T3 Torx driver to remove the two 1.9 mm screws securing the trackpad cable's cover bracket.
Remove the bracket.
Use a spudger to pry up the retaining flap on the trackpad ribbon cable's ZIF connector.
Één andere persoon heeft deze handleiding voltooid.
2 Opmerkingen
Is there any way to fix the track pad without having to replace it? I think I got some tea spilled on it. So right bottom corner does not flex/click.
Unlike the older Trackpads the newer Touchpads use a Taptic engine (the coils along the bottom) for the click action to give you the feel of the depressing the pad.
Sadly, you can’t really fix these as they get jammed up with what was spilled and you can’t soak the pad in anything as that would ruin it. Damed and double damed!
Dan -
