Inleiding
Use this guide to replace the heatsink in your MacBook Pro 13" 2022 (M2).
If your battery is swollen, take appropriate precautions.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the procedure.
Wat je nodig hebt
Unplug all cables and fully shut down your MacBook.
Close the lid and flip your MacBook over. Keep the lid closed until you've physically disconnected the battery.
Use a P5 Pentalobe driver to remove the six screws securing the lower case:
Two 6.8 mm screws
Two 5.3 mm screws
Two 3.4 mm screws
Apply a suction handle near the front edge of the lower case, between the screw holes.
Pull up on the suction handle to create a gap between the lower case and the frame.
Insert an opening pick between the lower case and the frame.
Slide the pick around the left corner to release the first set of clips.
Slide your opening pick around the right corner to release the second set of clips securing the lower case.
Insert your opening pick between the lower case and the frame near the middle left screw hole.
Firmly twist the pick until the clip releases.
Repeat this procedure for the clip near the middle right screw hole.
Firmly pull the lower case away from the screen hinges to release the last clips securing it to the frame.
Remove the lower case.
Set it in place and align the sliding clips near the display hinges. Press down and slide the lower case toward the hinges.
Once the lower case is secured near the hinges, press down firmly to engage the remaining four clips.
Use blunt nose tweezers or your fingers to peel and remove the cover from the battery board, just above the middle battery cell.
Use blunt nose tweezers to gently peel back the pull tab covering the battery data connector.
Use a T5 Torx driver to remove the 3.7 mm screw securing the battery connector.
Use the flat end of your spudger to slightly lift the battery connector away from the battery board.
Use a T3 Torx driver to remove the two 3.1 mm screws securing the display cable retaining bracket.
Remove the bracket.
Use your T3 Torx driver to remove the two 1.7 mm screws securing the display cable cover.
Remove the cover.
Use the flat end of your spudger to pry up and disconnect the display cable from the display board.
Use your T5 Torx driver to remove the two screws securing the left cable bracket to the logic board:
One 3.6 mm screw
One 2.6 mm screw
Remove the bracket.
Use the flat end of your spudger to pry up and disconnect the left interconnect cable.
Peel and remove the plastic cover from the antenna cables.
Use the point of your spudger to pry up and disconnect the antenna cables from the logic board.
Use your T5 Torx driver to remove the 3.4 mm screw securing the antenna cables to the logic board.
Use the point of a spudger to flip up the small locking tab securing the right speaker connector.
Grab the pull tab on the head of the cable and slide it straight out of its socket.
Use your T5 Torx driver to remove the two 1.9 mm screws securing the trackpad cable bracket.
Remove the bracket.
Use the flat end of your spudger to pry up and disconnect the trackpad cable from the logic board.
Use your T3 Torx driver to remove the three 1.4 mm screws securing the cable bracket to the top right of the logic board.
Remove the bracket.
Use the point of your spudger to pry up and disconnect the Touch Bar press connector from the top right of the logic board.
Repeat this step for the lid angle sensor and the Thunderbolt ports press connectors.
Use your T3 Torx driver to remove the two screws securing the cable cover near the headphone jack:
One 1.4 mm screw
One 4.9 mm screw
Remove the cover.
Remove the five screws securing the logic board:
One 3.0 mm hex head screw
One 3.7 mm T5 Torx screw
Three 3.3 mm T5 Torx screws
Thread the screw in using your fingertips.
Thread the screw in using blunt nose tweezers.
Use your T3 Torx driver to install the 1.4 mm screw into the hex head screw. Then, install the hex head screw using the T3 Torx driver. Finally, hold the hex head screw while you remove the 1.4 mm screw.
Once the hex head screw is threaded in a few turns, tighten it using your nut driver.
Insert the point of your spudger between the bottom left of the logic board and the left speaker assembly.
Pry up on the logic board until you can grab it with your fingers.
Grip the bottom left edge of the logic board.
Pull the logic board down and left to free it from the press connectors and antenna cables in the upper right corner.
Lift the logic board out of its recess, making sure not to catch on any loose cables.
Flip the logic board over and lay it down on a soft surface, such as a microfiber cloth.
Use a Torx T5 driver to unfasten the four 3.8 mm screws securing the tension brackets.
As you remove each screw, hold down the tension bracket with a finger to prevent the screw from ejecting.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
