Inleiding
Use this guide to replace the antenna bar in your MacBook Pro 13" 2022 (M2).
If your battery is swollen, take appropriate precautions.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the procedure.
Wat je nodig hebt
Unplug all cables and fully shut down your MacBook.
Close the lid and flip your MacBook over. Keep the lid closed until you've physically disconnected the battery.
Gereedschap gebruikt in deze stap:FixMat$36.95
Use a P5 Pentalobe driver to remove the six screws securing the lower case:
Two 6.8 mm screws
Two 5.3 mm screws
Two 3.4 mm screws
Apply a suction handle near the front edge of the lower case, between the screw holes.
Pull up on the suction handle to create a gap between the lower case and the frame.
Insert an opening pick between the lower case and the frame.
Slide the pick around the left corner to release the first set of clips.
Slide your opening pick around the right corner to release the second set of clips securing the lower case.
Insert your opening pick between the lower case and the frame near the middle left screw hole.
Firmly twist the pick until the clip releases.
Repeat this procedure for the clip near the middle right screw hole.
Firmly pull the lower case away from the screen hinges to release the last clips securing it to the frame.
Remove the lower case.
Set it in place and align the sliding clips near the display hinges. Press down and slide the lower case toward the hinges.
Once the lower case is secured near the hinges, press down firmly to engage the remaining four clips.
Use blunt noise tweezers or your fingers to peel and remove the cover from the battery board, just above the middle battery cell.
Use blunt nose tweezers to gently peel back the pull tab covering the battery data connector.
Use a T5 Torx driver to remove the 3.7 mm screw securing the battery connector.
Use the flat end of your spudger to slightly lift the battery connector away from the battery board.
Use a T3 Torx driver to remove the two 3.1 mm screws securing the display cable retaining bracket.
Remove the bracket.
Use your T3 Torx driver to remove the two 1.7 mm screws securing the display cable cover.
Remove the cover.
Use the flat end of your spudger to pry up and disconnect the display cable from the display board.
Use your T3 Torx driver to remove the four 3.3 mm screws securing the plastic covers to the screen hinges, one on each side.
Peel and remove the plastic cover from the antenna cables.
Use the point of your spudger to pry up and disconnect the antenna cables from the logic board.
Use your T3 Torx driver to remove the four 1.5 mm screws securing the two display board cable covers.
Remove the covers.
Remove the sixteen screws securing the antenna bar:
Four 3.3 mm T5 Torx screws, two on each side
Twelve 1.1 mm P2 Pentalobe screws, six on each side
Use your T5 Torx driver to remove the 3.4 mm screw securing the antenna cables to the logic board.
Insert your opening pick between the antenna bar and the frame.
Pry at different spots along the length of the antenna bar to free it from its recess in the frame.
Pull the left edge of the antenna bar away from the frame and feed its two antenna cables out from underneath the cutouts in the frame.
Remove the antenna bar.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
