Ga door naar hoofdinhoud
MacBook Air 13" Late 2020 Right Speaker Replacement
Wat je nodig hebt
  1. MacBook Air 13" Late 2020 Right Speaker Replacement, Remove the screws securing the lower case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  2. MacBook Air 13" Late 2020 Right Speaker Replacement, Remove the lower case: stap 2, afbeelding 1 van 3 MacBook Air 13" Late 2020 Right Speaker Replacement, Remove the lower case: stap 2, afbeelding 2 van 3 MacBook Air 13" Late 2020 Right Speaker Replacement, Remove the lower case: stap 2, afbeelding 3 van 3
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
  3. MacBook Air 13" Late 2020 Right Speaker Replacement, Disconnect the battery: stap 3, afbeelding 1 van 3 MacBook Air 13" Late 2020 Right Speaker Replacement, Disconnect the battery: stap 3, afbeelding 2 van 3 MacBook Air 13" Late 2020 Right Speaker Replacement, Disconnect the battery: stap 3, afbeelding 3 van 3
    • Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
    • Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch.
    • Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
    • During reassembly, press the battery connector straight down into its socket, making sure it sits flush within the socket.
    • If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
  4. MacBook Air 13" Late 2020 Right Speaker Replacement, Remove the audio board connector cover: stap 4, afbeelding 1 van 1
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
    • If your T3 bit feels a bit too loose, you may need to use a T4.
  5. MacBook Air 13" Late 2020 Right Speaker Replacement: stap 5, afbeelding 1 van 1
    • Remove the audio board connector cover.
  6. MacBook Air 13" Late 2020 Right Speaker Replacement, Disconnect the right speaker connector: stap 6, afbeelding 1 van 3 MacBook Air 13" Late 2020 Right Speaker Replacement, Disconnect the right speaker connector: stap 6, afbeelding 2 van 3 MacBook Air 13" Late 2020 Right Speaker Replacement, Disconnect the right speaker connector: stap 6, afbeelding 3 van 3
    • The right speaker will be on your lefthand side when working on the MacBook, as it's laying upside down.
    • Slide the pointed end of a spudger underneath the right speaker cable and pry straight up to disconnect it from the audio board.
  7. MacBook Air 13" Late 2020 Right Speaker Replacement, Remove the right speaker screw: stap 7, afbeelding 1 van 1
    • Use a T3 Torx driver to remove the 4.2 mm screw securing the right speaker to the case.
  8. MacBook Air 13" Late 2020 Right Speaker Replacement, Remove the speaker's stretch-release adhesive: stap 8, afbeelding 1 van 2 MacBook Air 13" Late 2020 Right Speaker Replacement, Remove the speaker's stretch-release adhesive: stap 8, afbeelding 2 van 2
    • Use a pair of tweezers to peel back the black pull tab on the speaker's stretch-release adhesive until you can grip it with your fingers.
  9. MacBook Air 13" Late 2020 Right Speaker Replacement: stap 9, afbeelding 1 van 2 MacBook Air 13" Late 2020 Right Speaker Replacement: stap 9, afbeelding 2 van 2
    • Grab the adhesive strip's pull tab and slowly pull the adhesive strip out from underneath the speaker.
    • Keep the angle of the adhesive strip as parallel to the laptop as you can. Try to avoid dragging it across the inside of the case.
    • Pull the adhesive strip until it's freed from under the speaker.
    • If the adhesive strip breaks, use a heated iOpener, a heat gun, or a hair dryer to help remove the adhesive:
    • Apply heat to the speaker to soften the adhesive underneath.
    • Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
  10. MacBook Air 13" Late 2020 Right Speaker Replacement, Remove the right speaker: stap 10, afbeelding 1 van 2 MacBook Air 13" Late 2020 Right Speaker Replacement, Remove the right speaker: stap 10, afbeelding 2 van 2
    Tesa 61395 Tape
    $5.99
    • Remove the right speaker.
    • During reassembly, to ensure the speaker performs as expected, install a strip of replacement adhesive on its underside before placing it back into the case.
Conclusie
Once you've completed your repair, your laptop may not power back on until connected to power.
Carsten Frauenheim
135.539 Reputatie
371 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.418 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 78
Afgelopen 30 dagen: 281
Altijd: 10,624
