Inleiding
Use this guide to replace the fan in an Early 2020 MacBook Air.
Wat je nodig hebt
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Slide the pointed end of a spudger underneath the speaker cable and pry straight up to disconnect it.
Use a T4 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
Remove the audio board connector cover.
Use a T4 Torx driver to remove the three screws securing the audio board:
Two 4.3 mm screws
One 2.4 mm screw
Use a pair of tweezers to peel back the black tape covering the fan cable connector.
Use the pointed end of a spudger to lift up the small locking flap on the fan cable's ZIF connector.
Slide the fan cable out of its connector.
Slide an opening pick underneath the audio board cable to separate it from the fan.
Use a T4 Torx driver to remove the three 2.7 mm screws securing the fan.
Één opmerking
Thank you very much. This helped me a lot when my fan started making buzzing noise an$ had the change it.
