Ga door naar hoofdinhoud
MacBook Air 11" Mid 2012 Solid-State Drive Replacement
Wat je nodig hebt
    1. MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Lower Case: stap 1, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Air 11" Mid 2012 Solid-State Drive Replacement: stap 2, afbeelding 1 van 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Battery: stap 3, afbeelding 1 van 2 MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Battery: stap 3, afbeelding 2 van 2
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Solid-State Drive: stap 4, afbeelding 1 van 1
      • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Air 11" Mid 2012 Solid-State Drive Replacement: stap 5, afbeelding 1 van 2 MacBook Air 11" Mid 2012 Solid-State Drive Replacement: stap 5, afbeelding 2 van 2
      • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
      • Do not lift the end of the SSD excessively.
      • Pull the drive straight out of its socket and remove it from the logic board.
      • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
52 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
515.422 Reputatie
406 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
42.773 handleidingen geschreven
4Gids Commentaar
Excellent instructions. Very easy to do. I used this screwdriver to remove the screws from the bottom of the case: https://www.amazon.com/gp/product/B00N1R...
and I used the Pentalobe-6 from this set to remove the screw holding in the OEM SSD:
https://www.amazon.com/gp/product/B01FE2...
After removing the stock drive, I installed a Samsung M.2 EVO 850 512Gb drive. It is working quite well. I used this adapter so that the M.2 drive fit in my 2012 Macbook Air:
https://www.amazon.com/gp/product/B01NH2...
feinberj - Antwoord Deel
How do we reinstall MacOS?
Philippe Morin - Antwoord Deel
I am 10 years old I fixed the mac I did this even the Geek squad couldn’t do it and now it works! without your guide.
admin free - Antwoord Deel
I have a MBA mid 2012 11” which no longer powers up. The battery has been in bad condition since a while and now the charging indicator remains amber no matter how long I charge it. So I assume it might be a battery issue. Unfortunately, I cannot find a supplier shipping batteries to Hawaii, but I found an identical machine on ebay (that will ship to Hawaii), except that it has 4GB RAM instead of 8GB. Provided my SSD is functional (which I assume) can I simply put my SSD into that 4GB RAM machine, and it will start up without any further modification?
Guido eMail - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 159
Altijd: 88,053
