Ga door naar hoofdinhoud
MSI PE70 6QE-035US speaker Replacement
Oscar Luis-Martinez
Oscar Luis-Martinez en 2 andere bijdragers
Voor het laatst geüpdatet op May 14, 2024
Geen schatting
Gemiddeld
Ontbrekende informatie
This guide will help you replace the speakers inside of the MSI PE70 6QE-035US. If your device has been having problems producing sound, replacing the speaker could be the solution you're looking for. Be sure to do these steps on a hard surface or anywhere that will not create any static electricity.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. MSI PE70 6QE-035US speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Start by flipping the device over to the backside.
    • Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
  2. MSI PE70 6QE-035US speaker Replacement: stap 2, afbeelding 1 van 2 MSI PE70 6QE-035US speaker Replacement: stap 2, afbeelding 2 van 2
    • After you remove the back panel, you should now see the 3 speakers.
    • We will start with the bottom most speaker.
  3. MSI PE70 6QE-035US speaker Replacement: stap 3, afbeelding 1 van 2 MSI PE70 6QE-035US speaker Replacement: stap 3, afbeelding 2 van 2
    • Using the ifixit opening tool, remove the speaker by gently unplugging its cord from the motherboard. Be sure to unplug the cord in the direction shown by the arrow.
    • After the cord has been unplugged, the speaker should now be able to be lifted out.
  4. MSI PE70 6QE-035US speaker Replacement: stap 4, afbeelding 1 van 3 MSI PE70 6QE-035US speaker Replacement: stap 4, afbeelding 2 van 3 MSI PE70 6QE-035US speaker Replacement: stap 4, afbeelding 3 van 3
    • These two speakers will be taken out together because they are held in by the same cord.
    • Once you have unplugged the cord, both speakers should be able to be lifted out.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 80
