MSI PE70 6QE-035US Hard Drive Replacement
Inleiding
Ga naar stap 1This guide will show you how to replace the hard drive inside of the MSI PE70 6QE-035US. If your device is struggling to download new files or applications, replacing your hard drive could be the fix to your problem. Be sure to follow this guide on any hard surface or area that won't create any static electricity.
Wat je nodig hebt
Start by flipping the device over to the backside.
Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
Één andere persoon heeft deze handleiding voltooid.
