Inleiding
If your Logitech G705 is not turning on, only works when plugged in, or has poor battery life, you may need to replace the battery. The repair is simple, but you must be careful with the delicate wires, ribbon cables, and the battery.
Before you begin, test the battery by charging it with a different cable to rule out a faulty cable. Also, make sure the mouse is clean and that all cables are connected within the mouse.
Power off the device before beginning the repair. As soon as possible, disconnect the battery to avoid damaging the device and possible injuries.
If the battery within your Logitech G705 is swollen, please follow the steps in this article.
For information on what to do with the old battery, please refer to the Wiki on How to Recycle End-of-Life Electronics.
Wat je nodig hebt
Remove the skate pads from the bottom of the mouse by peeling them off to access the screws.
Use the point of a plastic spudger to push on alternating sides of the connector to "walk" it out of its socket.
If that doesn't work, use a pair of tweezers to firmly grip the sides of the battery connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
