Ga door naar hoofdinhoud
Logitech G Pro Wireless Mouse Side Button Switch Replacement
Wat je nodig hebt
    1. Logitech G Pro Wireless Mouse Side Button Switch Replacement, Side Button Switch: stap 1, afbeelding 1 van 1
      • OPTIONAL BUT RECOMMENDED STEPS:
      • Find a stable desk or table to work on.
      • Create a clean work area on the surface.
      • Set up a mat on the work area.
      • Place the mouse on the work area.
      Vraag FixBot
      Voeg opmerking toe
    2. Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 2, afbeelding 1 van 1
      • Flip the power switch to OFF.
      • The power switch is located on the bottom of the mouse.
      Vraag FixBot
      Voeg opmerking toe
    3. Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 3, afbeelding 1 van 2 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 3, afbeelding 2 van 2
      • Optional: Gently apply heat to the bottom of mouse using heat gun for easier removal of skates. If you intend to reuse the skates, take care not to strain, warp, or tear them.
      • Use a spudger to gently lift and remove the five skates.
      Vraag FixBot
      Voeg opmerking toe
    4. Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 4, afbeelding 1 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 4, afbeelding 2 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 4, afbeelding 3 van 3
      • Remove the seven 4.4 mm-long Phillips #00 screws on the bottom shell of the mouse.
      • The screws are located underneath the edge skates.
      • Place the screws into a container to avoid losing them. Organize the screws into separate containers based on the step they were removed on to avoid incorrect reassembly.
      Vraag FixBot
      Voeg opmerking toe
    5. Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 5, afbeelding 1 van 2 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 5, afbeelding 2 van 2
      • Separate the bottom shell of the mouse from the top shell.
      • Remove the single 3 mm-long Phillips #00 screw securing the battery bracket.
      • Pop the battery out gently with the spudger.
      • Be careful not to damage the battery as it can leak toxic chemicals, catch fire, or explode.
      Vraag FixBot
      Voeg opmerking toe
    6. Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 6, afbeelding 1 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 6, afbeelding 2 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 6, afbeelding 3 van 3
      • Use the tweezers to lift up the electrical ribbon locking tab.
      • Gently pull out the ribbon to separate the bottom shell and top shell of the mouse.
      • If the ribbon does not release, gently wiggle the ribbon while carefully pulling to remove. Do not forcefully pull the ribbon as it can get damaged.
      Vraag FixBot
      Voeg opmerking toe
    7. Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 7, afbeelding 1 van 1
      • Remove the four 3 mm-long Phillips #00 screws securing the left and right mouse buttons on the inside of the top shell.
      Vraag FixBot
      Voeg opmerking toe
    8. Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 8, afbeelding 1 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 8, afbeelding 2 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 8, afbeelding 3 van 3
      • Flip the top shell over.
      • Remove the right and left mouse buttons.
      Vraag FixBot
      Voeg opmerking toe
    9. Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 9, afbeelding 1 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 9, afbeelding 2 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 9, afbeelding 3 van 3
      • Using the screwdriver, remove the two 3 mm-long Phillips #00 screws securing the middle housing assembly inside the mouse. Set the screws aside in a safe place to avoid losing them.
      • Using the spudger, gently pry up the middle housing assembly from the edges. Carefully lift the middle section out of the mouse body.
      Vraag FixBot
      Voeg opmerking toe
    10. Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 10, afbeelding 1 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 10, afbeelding 2 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 10, afbeelding 3 van 3
      • Using the screwdriver, remove the four 3 mm-long Phillips #00 screws securing the scroll wheel assembly to the mouse.
      • Using the spudger, gently lift the small ribbon cable connector from the circuit board. Carefully disconnect the ribbon cable by pulling it straight out of the connector.
      • Do not pull on the ribbon cable itself. Always lift from the connector to avoid tearing the cable.
      • Once disconnected, lift and remove the scroll wheel assembly from the mouse.
      Vraag FixBot
      Voeg opmerking toe
    11. Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 11, afbeelding 1 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 11, afbeelding 2 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 11, afbeelding 3 van 3
      • Using the screwdriver, remove the four 3mm Phillips #00 screws securing the blue side button brackets on both sides of the mouse.
      • Remove the nine 3 mm-long Phillips #00 screws securing the main internal frame (black plastic structure).
      • Remove the single 3mm Phillips #00 screw at the top of the mouse near the front end.
      • Set all screws aside in an organized manner to avoid mixing them up.
      Vraag FixBot
      Voeg opmerking toe
    12. Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 12, afbeelding 1 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 12, afbeelding 2 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 12, afbeelding 3 van 3
      • Carefully lift the internal assembly out of the outer mouse shell. Set the outer shell aside.
      • Remove the blue side button brackets from both sides of the internal frame.
      • Gently lift out the four side buttons from the frame.
      Vraag FixBot
      Voeg opmerking toe
    13. Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 13, afbeelding 1 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 13, afbeelding 2 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 13, afbeelding 3 van 3
      • Using the spudger, gently pry up the edge of the side circuit board from the plastic frame. Work your way along the edge, carefully releasing the clips holding the board in place.
      • Once loosened, lift the side circuit board away from the frame.
      Vraag FixBot
      Voeg opmerking toe
    14. Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 14, afbeelding 1 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 14, afbeelding 2 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 14, afbeelding 3 van 3
      • Using the spudger, gently insert the tip under the edge of the circuit board. Carefully pry upward to separate the board from the adhesive securing it to the frame.
      • Continue working along the edges until the adhesive is fully released. Once loosened, lift the circuit board assembly away from the frame.
      • If the adhesive is strong, apply slow, steady pressure instead of forcing it up quickly.
      Vraag FixBot
      Voeg opmerking toe
    15. Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 15, afbeelding 1 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 15, afbeelding 2 van 3 Logitech G Pro Wireless Mouse Side Button Switch Replacement: stap 15, afbeelding 3 van 3
      • Desolder the switch pins on the underside of the PCB.
      • Using the spudger, gently insert the tip underneath the side switch component. Carefully lift the edge of the switch to begin separating it from the board.
      • Use a second tool (such as tweezers or a flathead tool) to assist in prying the switch upward. Continue applying gentle pressure until the side switch is fully detached from the board.
      • Avoid applying excessive force, as this may damage the circuit board or surrounding components.
      • This is the final disassembly step. Begin reassembly starting here after replacing the button switch.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Shane Guzman
241 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 4-13, Harris Spring 2026 Lid van CSU Los Angeles, Team 4-13, Harris Spring 2026
CSULA-HARRIS-S26S4G13
3 Leden
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 87
Afgelopen 30 dagen: 331
Altijd: 673
