Lenovo V15-ADA Battery Replacement
Inleiding
Ga naar stap 1If your device isn’t charging or loses charge quickly, it may be time to replace the battery. Follow the instructions below to replace the battery in the Lenovo V15-ADA.
Before you begin this repair, make sure your laptop is powered off and unplugged from the charger.
Wat je nodig hebt
Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
M2.5 × 7 mm, Phillips-head (6) (RED circles)
M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
To start the removal of the battery, disconnect the ribbon cable connecting the battery to the computer.
