Ga door naar hoofdinhoud
Lenovo V14-ADA Battery Replacement
Samaya Roukoz
Samaya Roukoz en 5 andere bijdragers
Voor het laatst geüpdatet op October 1, 2024
5 minuten
Eenvoudig
If your Lenovo V14-ADA laptop (model 82C60072UE) is experiencing poor battery life and is not charging completely or will drain quickly when unplugged, use this replacement guide to help switch out the internal battery.
A good battery life is key when using a laptop; poor battery life or the battery quickly draining is not ideal because it can cause the laptop to not work efficiently.
Before beginning remove any power source from the laptop and make sure it is turned off, to ensure the most safe experience when replacing your battery.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. Lenovo V14-ADA Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down.
  2. Lenovo V14-ADA Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove all ten 5 mm screws from the back panel using a JIS #0 screwdriver.
  3. Lenovo V14-ADA Battery Replacement: stap 3, afbeelding 1 van 2 Lenovo V14-ADA Battery Replacement: stap 3, afbeelding 2 van 2
    • Place the Jimmy in the small crack between the back panel and the keyboard and push down.
    • Repeat this until the panel pops off.
  4. Lenovo V14-ADA Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Lenovo V14-ADA Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Remove the four 3 mm screws surrounding the battery using a JIS #0 screwdriver.
    • Slightly pull on the black wire connector to unplug the battery.
    • Lift up the battery to remove it from the laptop.
Conclusie
Samaya Roukoz
253 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 4-2, Shaddix Spring 2024 Lid van UMass Dartmouth, Team 4-2, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G2
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 30
Altijd: 129
