Ga door naar hoofdinhoud
Lenovo Thinkpad T410i Webcam Replacement
Harsh Patel
Harsh Patel en 3 andere bijdragers
Voor het laatst geüpdatet op January 4, 2018
10 - 15 minuten
Gemiddeld
This guide will show the removal / replacement process for the webcam above the LCD if damaged.
Guide Notes
  • You should only follow this guide after ruling out software issues from the list of problems and performing an exhaustive troubleshooting. Only replace your webcam if you are sure that the component is physically damaged. If your webcam stopped working after a liquid spillage or after crushing the webcam area, you may have to replace it.
  • Please look up and try troubleshooting solutions to common webcam software problems, such as missing or outdated drivers, disabled webcam, etc.
  • The webcam can be removed without first removing the LCD screen, although the screen is removed in this guide's pictures.
Wat je nodig hebt
Onderdelen
Gereedschap
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
Toon meer…
iFixit krijgt commissie als je dingen koopt via deze links.
  1. Lenovo Thinkpad T410i Webcam Replacement, Screen Bezel: stap 1, afbeelding 1 van 2 Lenovo Thinkpad T410i Webcam Replacement, Screen Bezel: stap 1, afbeelding 2 van 2
    • Use a spudger to remove the plastic covers from the LCD screen.
  2. Lenovo Thinkpad T410i Webcam Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 6.0mm screws on each side using Philips #0 head screwdriver as shown in the picture.
  3. Lenovo Thinkpad T410i Webcam Replacement: stap 3, afbeelding 1 van 1
    • Use a spudger to separate the bezel of the LCD screen.
  4. Lenovo Thinkpad T410i Webcam Replacement: stap 4, afbeelding 1 van 3 Lenovo Thinkpad T410i Webcam Replacement: stap 4, afbeelding 2 van 3 Lenovo Thinkpad T410i Webcam Replacement: stap 4, afbeelding 3 van 3
    • Continue along the edges lifting up and prying off the plastic LCD bezel.
  5. Lenovo Thinkpad T410i Webcam Replacement, Webcam: stap 5, afbeelding 1 van 1
    • Remove two 3.5mm Phillips #0 screws.
  6. Lenovo Thinkpad T410i Webcam Replacement: stap 6, afbeelding 1 van 1
    • Carefully detach the connector from webcam assembly.
    • Remove the webcam from the device.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Harsh Patel
287 Reputatie
2 handleidingen geschreven
USF Tampa, Team S1-G2, Thompson Fall 2017 Lid van USF Tampa, Team S1-G2, Thompson Fall 2017
USFT-THOMPSON-F17S1G2
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 680
