Ga door naar hoofdinhoud
Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement
Lex
Lex en 4 andere bijdragers
Voor het laatst geüpdatet op January 30, 2025
35 minuten - 1 uur
Gemiddeld
If the Lenovo ThinkPad Yoga 11e Gen 6 is having performance issues, (i.e., CPU response time, application launch time, system responsiveness, etc) it may need a new motherboard. Follow this guide to safely replace the motherboard in the Lenovo ThinkPad Yoga 11e Gen 6.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Wearing the anti-static wrist strap will prevent a static shock from damaging the components in the laptop.
    • Disconnect the laptop from power and make sure it is completely powered off.
    • Turn the laptop facing down.
    • Loosen the eight captive screws using a JIS #0 screwdriver.
    • The screws are attached to the panel and cannot be removed.
    • Use a spudger to release the tabs securing the back case and carefully remove the panel.
  2. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the three 4.5 mm screws from the battery using a JIS #0 screwdriver.
    • Lift the battery, then use your fingernail to slide the connector out of its socket.
    • Remove the battery.
  3. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement, Wi-Fi Board: stap 3, afbeelding 1 van 2 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement, Wi-Fi Board: stap 3, afbeelding 2 van 2
    • Push on alternating sides of the JST connector and pull straight away from the socket to disconnect the CMOS battery.
  4. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Lift the two wires and plastic piece away from the Wi-Fi board.
    • Remove the single 3 mm screw holding the Wi-Fi board in place using a Phillips #0 screwdriver.
    • Hold the sides of the Wi-Fi board and slide it out of the socket.
  5. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 3 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 3 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement, Motherboard: stap 5, afbeelding 3 van 3
    • Loosen the four captive screws from the metal panel with a copper strip on it using a Phillips #0 screwdriver.
    • Carefully lift the metal panel. The screws are attached to the panel and will not come out.
  6. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: stap 6, afbeelding 1 van 3 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: stap 6, afbeelding 2 van 3 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Pinch one of the display cable connectors and gently pull it out of its socket. Do the same for the 2nd display cable connector.
    • Pinch the sliding connector and slide it out.
    • Remove the 3 No-Fuss Ribbon Cable Connectors by pulling them out.
  7. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the three 4.5mm screws using a Phillips #0 screwdriver.
  8. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Gently lift and remove the motherboard out from the laptop.
Conclusie
Lex
509 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 45
Altijd: 134
