Ga door naar hoofdinhoud
Lenovo ThinkPad X270 Internal Battery Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X270 Internal Battery Replacement, Prepare your laptop for disassembly: stap 1, afbeelding 1 van 2 Lenovo ThinkPad X270 Internal Battery Replacement, Prepare your laptop for disassembly: stap 1, afbeelding 2 van 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo ThinkPad X270 Internal Battery Replacement, Remove the micro SIM card tray: stap 2, afbeelding 1 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Remove the micro SIM card tray: stap 2, afbeelding 2 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Remove the micro SIM card tray: stap 2, afbeelding 3 van 3
    • A SIM eject tool or bit isn't long enough to eject the tray.
    • Insert a straightened paper clip into the micro SIM card tray hole on the right edge of the laptop.
    • Press the paper clip firmly into the hole to eject the tray.
    • Remove the tray.
    • When reinserting the tray, slide the arms of the tray into the rectangular metal slot.
  3. Lenovo ThinkPad X270 Internal Battery Replacement, Battery information: stap 3, afbeelding 1 van 2 Lenovo ThinkPad X270 Internal Battery Replacement, Battery information: stap 3, afbeelding 2 van 2
    • Lay your laptop upside down to access the external battery.
    • Two sliding tabs secure the battery.
  4. Lenovo ThinkPad X270 Internal Battery Replacement, Release the left tab: stap 4, afbeelding 1 van 2 Lenovo ThinkPad X270 Internal Battery Replacement, Release the left tab: stap 4, afbeelding 2 van 2
    • Slide the left tab, labeled 1, to the unlocked position—it'll click into place and release the left side of the battery.
  5. Lenovo ThinkPad X270 Internal Battery Replacement, Remove the battery: stap 5, afbeelding 1 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Remove the battery: stap 5, afbeelding 2 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Remove the battery: stap 5, afbeelding 3 van 3
    • Hold the right tab, labeled 2, in the unlocked position and slide the battery out of its recess.
    • During reassembly, slide the battery into its recess until both tabs engage.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
  6. Lenovo ThinkPad X270 Internal Battery Replacement, Unfasten the back cover: stap 6, afbeelding 1 van 2 Lenovo ThinkPad X270 Internal Battery Replacement, Unfasten the back cover: stap 6, afbeelding 2 van 2
    • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
    • Don't try to completely remove the screws—they're secured to the back cover with delicate, plastic clips.
  7. Lenovo ThinkPad X270 Internal Battery Replacement, Insert an opening pick: stap 7, afbeelding 1 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Insert an opening pick: stap 7, afbeelding 2 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Insert an opening pick: stap 7, afbeelding 3 van 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the bottom right edge of the back cover and frame.
    • Pry up the back cover to release the bottom right clips.
    • Leave the pick inserted in the bottom right corner.
  8. Lenovo ThinkPad X270 Internal Battery Replacement, Release the bottom edge clips: stap 8, afbeelding 1 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Release the bottom edge clips: stap 8, afbeelding 2 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Release the bottom edge clips: stap 8, afbeelding 3 van 3
    • During the next two steps, position your pick downward at a 45-degree angle to help release the clips.
    • Slide the pick to the bottom left corner to release the bottom clips.
  9. Lenovo ThinkPad X270 Internal Battery Replacement, Release the left edge clips: stap 9, afbeelding 1 van 2 Lenovo ThinkPad X270 Internal Battery Replacement, Release the left edge clips: stap 9, afbeelding 2 van 2
    • Insert your pick in the bottom left corner and slide the pick to the first USB port to release the left clips.
  10. Lenovo ThinkPad X270 Internal Battery Replacement, Release the top corner clips: stap 10, afbeelding 1 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Release the top corner clips: stap 10, afbeelding 2 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Release the top corner clips: stap 10, afbeelding 3 van 3
    • Insert an opening tool between the top left corner of the back cover and frame.
    • Pry the back cover up to release the clips securing its top left corner.
    • Repeat the process on the top right corner.
  11. Lenovo ThinkPad X270 Internal Battery Replacement, Release the top edge clips: stap 11, afbeelding 1 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Release the top edge clips: stap 11, afbeelding 2 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Release the top edge clips: stap 11, afbeelding 3 van 3
    • Five clips secure the top edge of the back cover.
    • Insert an opening tool in the gap between the back cover and frame, next to one of the clips.
    • Push the opening tool into the gap until the clip releases.
  12. Lenovo ThinkPad X270 Internal Battery Replacement: stap 12, afbeelding 1 van 3 Lenovo ThinkPad X270 Internal Battery Replacement: stap 12, afbeelding 2 van 3 Lenovo ThinkPad X270 Internal Battery Replacement: stap 12, afbeelding 3 van 3
    • Push the opening tool between the back cover and frame at different points along the top edge to release the remaining clips.
  13. Lenovo ThinkPad X270 Internal Battery Replacement, Remove the back cover: stap 13, afbeelding 1 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Remove the back cover: stap 13, afbeelding 2 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Remove the back cover: stap 13, afbeelding 3 van 3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
  14. Lenovo ThinkPad X270 Internal Battery Replacement, Disconnect the internal battery: stap 14, afbeelding 1 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Disconnect the internal battery: stap 14, afbeelding 2 van 3 Lenovo ThinkPad X270 Internal Battery Replacement, Disconnect the internal battery: stap 14, afbeelding 3 van 3
  15. Lenovo ThinkPad X270 Internal Battery Replacement, Unfasten the battery: stap 15, afbeelding 1 van 2 Lenovo ThinkPad X270 Internal Battery Replacement, Unfasten the battery: stap 15, afbeelding 2 van 2
    • Avoid poking the battery with the tip of your screwdriver—a punctured or battery may leak dangerous chemicals or cause a fire.
    • Use a Phillips screwdriver to remove the three 4 mm‑long screws securing the internal battery.
  16. Lenovo ThinkPad X270 Internal Battery Replacement, Remove the battery: stap 16, afbeelding 1 van 2 Lenovo ThinkPad X270 Internal Battery Replacement, Remove the battery: stap 16, afbeelding 2 van 2
    • Remove the internal battery.
Conclusie
Check your repair by running hardware tests with Lenovo Diagnostics.
For optimal performance, calibrate your newly installed battery after completing this guide.
3 andere personen hebben deze handleiding voltooid.
Spencer Day
54.914 Reputatie
407 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.298 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 20
Afgelopen 7 dagen: 94
Afgelopen 30 dagen: 304
Altijd: 2,178
