Ga door naar hoofdinhoud
Lenovo ThinkPad T480s Wi-Fi Card Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Wi-Fi Card Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: stap 2, afbeelding 3 van 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Wi-Fi Card Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement: stap 3, afbeelding 2 van 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: stap 4, afbeelding 1 van 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: stap 4, afbeelding 2 van 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: stap 4, afbeelding 3 van 3
    • Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
    • When reassembling, reattach the gray wire closest to the screw and the black wire on the other side of the gray wire.
  5. Lenovo ThinkPad T480s Wi-Fi Card Replacement: stap 5, afbeelding 1 van 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement: stap 5, afbeelding 2 van 2
    • Use the Phillips #1 screwdriver to remove one 2.8mm screw holding the Wi-Fi card down to the motherboard.
  6. Lenovo ThinkPad T480s Wi-Fi Card Replacement: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: stap 6, afbeelding 3 van 3
    • Slide the Wi-Fi card out from the slot.
Conclusie
Sarah Westberg
23.242 Reputatie
70 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
17.204 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 116
Altijd: 1,898
