Ga door naar hoofdinhoud
Lenovo ThinkPad T480s Trackpad Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T480s Trackpad Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 Lenovo ThinkPad T480s Trackpad Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Trackpad Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T480s Trackpad Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T480s Trackpad Replacement: stap 2, afbeelding 3 van 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Trackpad Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T480s Trackpad Replacement: stap 3, afbeelding 2 van 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Trackpad Replacement, Battery: stap 4, afbeelding 1 van 2 Lenovo ThinkPad T480s Trackpad Replacement, Battery: stap 4, afbeelding 2 van 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Trackpad Replacement: stap 5, afbeelding 1 van 3 Lenovo ThinkPad T480s Trackpad Replacement: stap 5, afbeelding 2 van 3 Lenovo ThinkPad T480s Trackpad Replacement: stap 5, afbeelding 3 van 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Trackpad Replacement, Trackpad: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T480s Trackpad Replacement, Trackpad: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T480s Trackpad Replacement, Trackpad: stap 6, afbeelding 3 van 3
    • Use the spudger to disconnect the trackpad cable from the system board.
  7. Lenovo ThinkPad T480s Trackpad Replacement: stap 7, afbeelding 1 van 3 Lenovo ThinkPad T480s Trackpad Replacement: stap 7, afbeelding 2 van 3 Lenovo ThinkPad T480s Trackpad Replacement: stap 7, afbeelding 3 van 3
    • Peel the cable and black sticker to reveal a hidden screw.
  8. Lenovo ThinkPad T480s Trackpad Replacement: stap 8, afbeelding 1 van 2 Lenovo ThinkPad T480s Trackpad Replacement: stap 8, afbeelding 2 van 2
    • Use the Phillips #1 screwdriver to remove four 2.3 mm screws.
  9. Lenovo ThinkPad T480s Trackpad Replacement: stap 9, afbeelding 1 van 3 Lenovo ThinkPad T480s Trackpad Replacement: stap 9, afbeelding 2 van 3 Lenovo ThinkPad T480s Trackpad Replacement: stap 9, afbeelding 3 van 3
    • Open the bottom case and remove the trackpad.
    • The ribbon cable will slide through and out of the bottom of the case.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Sarah Westberg
23.381 Reputatie
70 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.442 handleidingen geschreven
3 opmerkingen
Thanks! Worked.
Drew - Antwoord
do you have a part number for the replacement trackpad?
Adam S - Antwoord
Hi Adam S, I did a search by the touchpad SKU and a general search by the make and model of the laptop but it didn't come up. Have you tried contacting Lenovo? It's possible they might have the part number even if they don't sell the part, but then you might be able to find it on the secondary market. This might be a good place to start: https://pcsupport.lenovo.com/us/en/solut.... I hope this helps!
Sarah Westberg -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 52
Afgelopen 30 dagen: 179
Altijd: 5,329
