Ga door naar hoofdinhoud
Lenovo ThinkPad T480s Speaker Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Speaker Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T480s Speaker Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T480s Speaker Replacement: stap 2, afbeelding 3 van 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Speaker Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T480s Speaker Replacement: stap 3, afbeelding 2 van 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Speaker Replacement, Battery: stap 4, afbeelding 1 van 2 Lenovo ThinkPad T480s Speaker Replacement, Battery: stap 4, afbeelding 2 van 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Speaker Replacement: stap 5, afbeelding 1 van 3 Lenovo ThinkPad T480s Speaker Replacement: stap 5, afbeelding 2 van 3 Lenovo ThinkPad T480s Speaker Replacement: stap 5, afbeelding 3 van 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Speaker Replacement, Speaker: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T480s Speaker Replacement, Speaker: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T480s Speaker Replacement, Speaker: stap 6, afbeelding 3 van 3
    • Disconnect the speaker cable from the motherboard using a connector puller or spudger.
  7. Lenovo ThinkPad T480s Speaker Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad T480s Speaker Replacement: stap 7, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the right side.
  8. Lenovo ThinkPad T480s Speaker Replacement: stap 8, afbeelding 1 van 3 Lenovo ThinkPad T480s Speaker Replacement: stap 8, afbeelding 2 van 3 Lenovo ThinkPad T480s Speaker Replacement: stap 8, afbeelding 3 van 3
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the left side.
  9. Lenovo ThinkPad T480s Speaker Replacement: stap 9, afbeelding 1 van 3 Lenovo ThinkPad T480s Speaker Replacement: stap 9, afbeelding 2 van 3 Lenovo ThinkPad T480s Speaker Replacement: stap 9, afbeelding 3 van 3
    • Use the spudger to disconnect the hall sensor connector.
  10. Lenovo ThinkPad T480s Speaker Replacement: stap 10, afbeelding 1 van 3 Lenovo ThinkPad T480s Speaker Replacement: stap 10, afbeelding 2 van 3 Lenovo ThinkPad T480s Speaker Replacement: stap 10, afbeelding 3 van 3
    • Lift the speakers up.
    • Disconnect the cable speakers from the routing.
    • Remove the speakers from the system.
Conclusie
Sarah Westberg
23.817 Reputatie
70 handleidingen geschreven
iFixit Lid van iFixit
Staff
140 Leden
17.686 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 57
Altijd: 1,420
