Ga door naar hoofdinhoud
Lenovo ThinkPad T480s Hall Sensor Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Hall Sensor Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T480s Hall Sensor Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T480s Hall Sensor Replacement: stap 2, afbeelding 3 van 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Hall Sensor Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T480s Hall Sensor Replacement: stap 3, afbeelding 2 van 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: stap 4, afbeelding 1 van 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: stap 4, afbeelding 2 van 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Hall Sensor Replacement: stap 5, afbeelding 1 van 3 Lenovo ThinkPad T480s Hall Sensor Replacement: stap 5, afbeelding 2 van 3 Lenovo ThinkPad T480s Hall Sensor Replacement: stap 5, afbeelding 3 van 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: stap 6, afbeelding 3 van 3
    • Use a spudger to disconnect the cable from the Hall sensor.
  7. Lenovo ThinkPad T480s Hall Sensor Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad T480s Hall Sensor Replacement: stap 7, afbeelding 2 van 2
    • With the Phillips #1 screwdriver, remove one 3.1 mm screw from the sensor.
  8. Lenovo ThinkPad T480s Hall Sensor Replacement: stap 8, afbeelding 1 van 3 Lenovo ThinkPad T480s Hall Sensor Replacement: stap 8, afbeelding 2 van 3 Lenovo ThinkPad T480s Hall Sensor Replacement: stap 8, afbeelding 3 van 3
    • Remove the sensor from the system.
Conclusie
Sarah Westberg
24.109 Reputatie
71 handleidingen geschreven
iFixit Lid van iFixit
Staff
141 Leden
17.895 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 117
Altijd: 2,574
