Ga door naar hoofdinhoud
Lenovo ThinkPad T480s Fan Assembly Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T480s Fan Assembly Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 Lenovo ThinkPad T480s Fan Assembly Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Fan Assembly Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T480s Fan Assembly Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T480s Fan Assembly Replacement: stap 2, afbeelding 3 van 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Fan Assembly Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T480s Fan Assembly Replacement: stap 3, afbeelding 2 van 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Fan Assembly Replacement, Fan Assembly: stap 4, afbeelding 1 van 2 Lenovo ThinkPad T480s Fan Assembly Replacement, Fan Assembly: stap 4, afbeelding 2 van 2
    • Use the spudger to disconnect the fan cable from the motherboard.
  5. Lenovo ThinkPad T480s Fan Assembly Replacement: stap 5, afbeelding 1 van 2 Lenovo ThinkPad T480s Fan Assembly Replacement: stap 5, afbeelding 2 van 2
    • Loosen the six captive screws attaching the fan assembly to the motherboard.
    • This system was missing the two screws by the fan but I have highlighted them to show where they are located.
  6. Lenovo ThinkPad T480s Fan Assembly Replacement: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T480s Fan Assembly Replacement: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T480s Fan Assembly Replacement: stap 6, afbeelding 3 van 3
    • Lift the thermal fan assembly from the system and remove it.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Sarah Westberg
29.665 Reputatie
71 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.612 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 37
Afgelopen 30 dagen: 249
Altijd: 4,554
