Ga door naar hoofdinhoud
Lenovo ThinkPad T480 Keyboard Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T480 Keyboard Replacement, External Battery: stap 1, afbeelding 1 van 2 Lenovo ThinkPad T480 Keyboard Replacement, External Battery: stap 1, afbeelding 2 van 2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Keyboard Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T480 Keyboard Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T480 Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
  4. Lenovo ThinkPad T480 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Open the laptop so the keyboard is facing you.
  5. Lenovo ThinkPad T480 Keyboard Replacement: stap 5, afbeelding 1 van 3 Lenovo ThinkPad T480 Keyboard Replacement: stap 5, afbeelding 2 van 3 Lenovo ThinkPad T480 Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Push the keyboard towards the screen and away from the trackpad and then slide it out towards you gently.
    • The keyboard is connected to the board by two ribbon connectors.
    • Be careful not to rip the connectors when you flip the keyboard over.
  6. Lenovo ThinkPad T480 Keyboard Replacement: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T480 Keyboard Replacement: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T480 Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Flip the keyboard over towards you to expose the backside of the keyboard and the two ribbon connectors.
    • Using the black nylon spudger, flip the first ribbon connector lock open. Slide the first connector out.
  7. Lenovo ThinkPad T480 Keyboard Replacement: stap 7, afbeelding 1 van 3 Lenovo ThinkPad T480 Keyboard Replacement: stap 7, afbeelding 2 van 3 Lenovo ThinkPad T480 Keyboard Replacement: stap 7, afbeelding 3 van 3
    • Using the black nylon spudger, unlock the second ribbon connector and slide it out from the port.
  8. Lenovo ThinkPad T480 Keyboard Replacement: stap 8, afbeelding 1 van 2 Lenovo ThinkPad T480 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Remove the keyboard from the laptop.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Sarah Westberg
23.198 Reputatie
70 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
17.182 handleidingen geschreven
3 opmerkingen
Thanks for this. I need help with my Lenovo Thinkpad T480 keyboard to motherboard connector pin. That is the third image in step 6.
Where can I get a replacement?
EagleCreeks Assortment - Antwoord
Hi @lioneeddev99026, You are most welcome. I'm glad the guide was helpful!
Sarah Westberg -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 106
Afgelopen 30 dagen: 489
Altijd: 11,809
