Ga door naar hoofdinhoud
Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, External Battery: stap 1, afbeelding 1 van 2 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, External Battery: stap 1, afbeelding 2 van 2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 2, afbeelding 3 van 3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, Back Cover: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, Back Cover: stap 3, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 4, afbeelding 3 van 3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, Internal Battery: stap 5, afbeelding 1 van 2 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, Internal Battery: stap 5, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, remove the two 4.6 mm screws securing the internal battery to the frame.
  6. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 6, afbeelding 3 van 3
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 7, afbeelding 1 van 3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 7, afbeelding 2 van 3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 7, afbeelding 3 van 3
    • Using the black nylon spudger, wedge the battery up from the case and lift it out.
  8. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, Fan Assembly/Heatsink: stap 8, afbeelding 1 van 2 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement, Fan Assembly/Heatsink: stap 8, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, loosen the four captive screws in the arm of the heatsink.
  9. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 9, afbeelding 1 van 2 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 9, afbeelding 2 van 2
    • Use the black nylon spudger to slide the fan connector parallel to the motherboard and out of its socket on the motherboard.
  10. Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 10, afbeelding 1 van 3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 10, afbeelding 2 van 3 Lenovo ThinkPad T480 Fan Assembly/Heatsink Replacement: stap 10, afbeelding 3 van 3
    • Lift the fan assembly off of the board.
    • Prior to replacing your fan assembly, remember to apply thermal paste.
Conclusie
Sarah Westberg
23.330 Reputatie
70 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.410 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 58
Afgelopen 30 dagen: 242
Altijd: 4,994
