Ga door naar hoofdinhoud
Lenovo ThinkPad T470 TrackPad Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T470 TrackPad Replacement, External Battery: stap 1, afbeelding 1 van 3 Lenovo ThinkPad T470 TrackPad Replacement, External Battery: stap 1, afbeelding 2 van 3 Lenovo ThinkPad T470 TrackPad Replacement, External Battery: stap 1, afbeelding 3 van 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 TrackPad Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 2, afbeelding 3 van 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 TrackPad Replacement, Internal Components: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement, Internal Components: stap 3, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 TrackPad Replacement: stap 4, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 4, afbeelding 2 van 2
    • Place the laptop so that the top is facing upwards.
    • Open the lid of the laptop.
  5. Lenovo ThinkPad T470 TrackPad Replacement: stap 5, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 5, afbeelding 2 van 2
    • Place your fingers on the bottom edge of the keyboard.
    • Use a small amount of pressure to push the keyboard towards the screen.
  6. Lenovo ThinkPad T470 TrackPad Replacement: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 6, afbeelding 3 van 3
    • Grab the bottom edge of the keyboard with your hands, and flip the keyboard upside-down, so it rests on the bottom of the laptop.
    • Potential for device damage: The keyboard is still attached to the rest of the laptop, so be gentle when flipping it over.
  7. Lenovo ThinkPad T470 TrackPad Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 7, afbeelding 2 van 2
    • Use the flat end of a spudger to flip up the locking flaps securing each of the two ribbon cables.
  8. Lenovo ThinkPad T470 TrackPad Replacement: stap 8, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 8, afbeelding 2 van 2
    • Use your hands to lift the keyboard up and away from the laptop.
  9. Lenovo ThinkPad T470 TrackPad Replacement: stap 9, afbeelding 1 van 1
    • Close the laptop's lid and flip the laptop over so that the bottom is facing upwards.
  10. Lenovo ThinkPad T470 TrackPad Replacement: stap 10, afbeelding 1 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 10, afbeelding 2 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 10, afbeelding 3 van 3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  11. Lenovo ThinkPad T470 TrackPad Replacement: stap 11, afbeelding 1 van 1
    • Remove the bottom cover from the laptop.
  12. Lenovo ThinkPad T470 TrackPad Replacement: stap 12, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 12, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove two 5 mm screws from the internal battery.
  13. Lenovo ThinkPad T470 TrackPad Replacement: stap 13, afbeelding 1 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 13, afbeelding 2 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 13, afbeelding 3 van 3
    • Use your hands to lift the battery up and away from the laptop.
  14. Lenovo ThinkPad T470 TrackPad Replacement: stap 14, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 14, afbeelding 2 van 2
    • Use your fingers to flip the black flap covering the top stick of RAM down.
  15. Lenovo ThinkPad T470 TrackPad Replacement: stap 15, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 15, afbeelding 2 van 2
    • Use your thumbs to push the metal clips on either end of the RAM outwards.
    • The RAM will pop up by a few millimeters.
  16. Lenovo ThinkPad T470 TrackPad Replacement: stap 16, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 16, afbeelding 2 van 2
    • Use your fingers to lift the RAM out of its socket and away from the laptop to remove it.
  17. Lenovo ThinkPad T470 TrackPad Replacement: stap 17, afbeelding 1 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 17, afbeelding 2 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 17, afbeelding 3 van 3
    • Use your fingers to flip the black flap covering the bottom stick of RAM up.
  18. Lenovo ThinkPad T470 TrackPad Replacement: stap 18, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 18, afbeelding 2 van 2
  19. Lenovo ThinkPad T470 TrackPad Replacement: stap 19, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 19, afbeelding 2 van 2
    • Use the flat end of a spudger to flip up the metal clip securing the SSD connector to the motherboard.
  20. Lenovo ThinkPad T470 TrackPad Replacement: stap 20, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 20, afbeelding 2 van 2
    • Use the flat end of a spudger to separate the connector from its socket.
  21. Lenovo ThinkPad T470 TrackPad Replacement: stap 21, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 21, afbeelding 2 van 2
    • Grab the tab on the left side of the hard drive, and pull up to remove it from the laptop.
  22. Lenovo ThinkPad T470 TrackPad Replacement: stap 22, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 22, afbeelding 2 van 2
    • Use a finger to press the black flap covering the Wi-Fi card down.
  23. Lenovo ThinkPad T470 TrackPad Replacement: stap 23, afbeelding 1 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 23, afbeelding 2 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 23, afbeelding 3 van 3
    • Use the flat end of a spudger to disconnect the two coaxial wires from the Wi-Fi card.
    • When reassembling, reattach the gray wire on the left and the black wire on the right.
  24. Lenovo ThinkPad T470 TrackPad Replacement: stap 24, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 24, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the single 4 mm screw from the Wi-Fi card.
  25. Lenovo ThinkPad T470 TrackPad Replacement: stap 25, afbeelding 1 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 25, afbeelding 2 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 25, afbeelding 3 van 3
    • Use your fingers to lift the Wi-Fi card up and out of its slot.
    • This laptop does not include a WWAN card, but if yours does, follow the same procedure as Steps 9-12 to remove it.
  26. Lenovo ThinkPad T470 TrackPad Replacement: stap 26, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 26, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of blunt nose tweezers to pull the white connector out of its socket.
  27. Lenovo ThinkPad T470 TrackPad Replacement: stap 27, afbeelding 1 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 27, afbeelding 2 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 27, afbeelding 3 van 3
    • Grab the wire attached to the coin cell battery, and lift it up and out of the laptop.
  28. Lenovo ThinkPad T470 TrackPad Replacement: stap 28, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 28, afbeelding 2 van 2
    • Use a pair of blunt nose tweezers to pull the white fan connector out of its socket on the motherboard.
  29. Lenovo ThinkPad T470 TrackPad Replacement: stap 29, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to loosen the first pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
    • Use a Phillips #1 screwdriver to loosen the second pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
  30. Lenovo ThinkPad T470 TrackPad Replacement: stap 30, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 30, afbeelding 2 van 2
    • Use your hand to pull the fan and heat sink assembly up and away from the laptop.
    • Clean the thermal paste from the heatsink and CPU and reapply fresh paste before reassembling.
  31. Lenovo ThinkPad T470 TrackPad Replacement, Motherboard: stap 31, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement, Motherboard: stap 31, afbeelding 2 van 2
    • Use the flat end of a spudger to flip up the metal clip securing the LCD cable to the motherboard.
  32. Lenovo ThinkPad T470 TrackPad Replacement: stap 32, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 32, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the LCD cable from its socket on the motherboard.
  33. Lenovo ThinkPad T470 TrackPad Replacement: stap 33, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 33, afbeelding 2 van 2
    • Use the flat end of a spudger to flip the power button cable's black tab up.
  34. Lenovo ThinkPad T470 TrackPad Replacement: stap 34, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 34, afbeelding 2 van 2
    • Use the flat end of a spudger to slide the power button cable out of its connector on the motherboard.
  35. Lenovo ThinkPad T470 TrackPad Replacement: stap 35, afbeelding 1 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 35, afbeelding 2 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 35, afbeelding 3 van 3
    • Use your fingers to detach the red and blue antenna cables from their slots.
  36. Lenovo ThinkPad T470 TrackPad Replacement: stap 36, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 36, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the two 4 mm screws from the USB bracket.
  37. Lenovo ThinkPad T470 TrackPad Replacement: stap 37, afbeelding 1 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 37, afbeelding 2 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 37, afbeelding 3 van 3
    • Use your fingers to lift the USB bracket up and away from the laptop.
  38. Lenovo ThinkPad T470 TrackPad Replacement: stap 38, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 38, afbeelding 2 van 2
    • Use a pair of blunt nose tweezers to disconnect the DC-in cable from its socket on the motherboard.
  39. Lenovo ThinkPad T470 TrackPad Replacement: stap 39, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 39, afbeelding 2 van 2
    • Use the flat end of a spudger to flip up the metal bracket securing the camera cable to the motherboard.
  40. Lenovo ThinkPad T470 TrackPad Replacement: stap 40, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 40, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the camera cable from its socket on the motherboard.
  41. Lenovo ThinkPad T470 TrackPad Replacement: stap 41, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 41, afbeelding 2 van 2
    • Use a pair of blunt nose tweezers to disconnect the speaker cable from its socket on the motherboard.
  42. Lenovo ThinkPad T470 TrackPad Replacement: stap 42, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 42, afbeelding 2 van 2
    • Use the flat end of a spudger to flip up the black tabs on the trackpad and fingerprint reader cables.
  43. Lenovo ThinkPad T470 TrackPad Replacement: stap 43, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 43, afbeelding 2 van 2
    • Use a pair of blunt nose tweezers to slide the trackpad and fingerprint reader cables out of their connectors on the motherboard.
  44. Lenovo ThinkPad T470 TrackPad Replacement: stap 44, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 44, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the three 4 mm screws from the I/O bracket.
  45. Lenovo ThinkPad T470 TrackPad Replacement: stap 45, afbeelding 1 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 45, afbeelding 2 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 45, afbeelding 3 van 3
    • Use your fingers to slide the I/O bracket to the left.
    • Lift the I/O bracket up and away from the laptop.
  46. Lenovo ThinkPad T470 TrackPad Replacement: stap 46, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 46, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the six 4 mm screws from the motherboard.
    • This laptop does not have an NFC cable, but if yours does, use the flat end of a spudger to flip up the tab and slide the cable out of its connector.
  47. Lenovo ThinkPad T470 TrackPad Replacement: stap 47, afbeelding 1 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 47, afbeelding 2 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 47, afbeelding 3 van 3
    • Use both hands to lift the motherboard up and away from the laptop.
  48. Lenovo ThinkPad T470 TrackPad Replacement, Trackpad: stap 48, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement, Trackpad: stap 48, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the four 4 mm screws.
  49. Lenovo ThinkPad T470 TrackPad Replacement: stap 49, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 49, afbeelding 2 van 2
    • Peel up the white ribbon cable.
    • Potential for device damage: The cable may be attached to the laptop with strong adhesive, so be cautious not to tear it.
  50. Lenovo ThinkPad T470 TrackPad Replacement: stap 50, afbeelding 1 van 2 Lenovo ThinkPad T470 TrackPad Replacement: stap 50, afbeelding 2 van 2
    • Use both hands to lift up the bottom frame of the laptop a few centimeters.
  51. Lenovo ThinkPad T470 TrackPad Replacement: stap 51, afbeelding 1 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 51, afbeelding 2 van 3 Lenovo ThinkPad T470 TrackPad Replacement: stap 51, afbeelding 3 van 3
    • Hold the frame up with one hand.
    • Use your other hand to slide the trackpad toward you and away from the laptop.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kristen Gismondi
92.493 Reputatie
241 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.604 handleidingen geschreven
Één opmerking
The disassembly process can be significantly simplified if all you want to do is replace the trackpad in the T470. Basically, you only need to do the following:
1. Turn off the internal battery via the Lenovo UFEI/BIOS settings.
2. Remove the external hot swappable battery.
3. Remove the bottom cover.
4. Remove the internal battery.
5. If installed, remove the second RAM card that is closest to the trackpad.
6. Unscrew the trackpad.
7. Remove and replace the trackpad.
See this video from January 2024 that shows this process:
https://youtu.be/q7elsgUMboc
Tai Lam - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 72
Altijd: 4,201
