Ga door naar hoofdinhoud
Lenovo ThinkPad T16 Gen 3 Battery Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T16 Gen 3 Battery Replacement, Prepare your laptop for disassembly: stap 1, afbeelding 1 van 3 Lenovo ThinkPad T16 Gen 3 Battery Replacement, Prepare your laptop for disassembly: stap 1, afbeelding 2 van 3 Lenovo ThinkPad T16 Gen 3 Battery Replacement, Prepare your laptop for disassembly: stap 1, afbeelding 3 van 3
    • For your safety, discharge your battery below 25% before disassembling your laptop. A charged battery may catch fire if damaged. If your battery is swollen, take appropriate precautions.
    • Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
    • Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
  2. Lenovo ThinkPad T16 Gen 3 Battery Replacement, Loosen the base cover screws: stap 2, afbeelding 1 van 2 Lenovo ThinkPad T16 Gen 3 Battery Replacement, Loosen the base cover screws: stap 2, afbeelding 2 van 2
    • Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
  3. Lenovo ThinkPad T16 Gen 3 Battery Replacement, Pry up the base cover: stap 3, afbeelding 1 van 3 Lenovo ThinkPad T16 Gen 3 Battery Replacement, Pry up the base cover: stap 3, afbeelding 2 van 3 Lenovo ThinkPad T16 Gen 3 Battery Replacement, Pry up the base cover: stap 3, afbeelding 3 van 3
    • Insert your fingernail or an opening pick into the gap between the base cover and keyboard deck, next to one of the screen hinges.
    • Pry up the base cover until the clips unfasten.
  4. Lenovo ThinkPad T16 Gen 3 Battery Replacement, Remove the base cover: stap 4, afbeelding 1 van 2 Lenovo ThinkPad T16 Gen 3 Battery Replacement, Remove the base cover: stap 4, afbeelding 2 van 2
    • Grasp the base cover along the screen hinge edge and lift slowly to unfasten the remaining clips.
    • Lift and remove the base cover.
    • During reassembly, lay the base cover into the frame, inserting it into the tabs along the battery edge. Press down firmly around the perimeter to reengage all the clips.
  5. Lenovo ThinkPad T16 Gen 3 Battery Replacement, Loosen the battery screws: stap 5, afbeelding 1 van 2 Lenovo ThinkPad T16 Gen 3 Battery Replacement, Loosen the battery screws: stap 5, afbeelding 2 van 2
    • Because of the battery connector's design, the only way to disconnect the battery is by physically removing it.
    • Use a Phillips screwdriver to fully loosen the two captive screws securing the battery connector.
  6. Lenovo ThinkPad T16 Gen 3 Battery Replacement, Remove the battery: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T16 Gen 3 Battery Replacement, Remove the battery: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T16 Gen 3 Battery Replacement, Remove the battery: stap 6, afbeelding 3 van 3
    • Lift the edge of the battery with the connector to disconnect it.
    • You may feel a little resistance from the battery connector as it disconnects—that's normal.
    • Remove the battery
    • During reassembly:
    • Slide the plastic tabs on the long edge of the battery into their recesses in the frame.
    • Lower the battery into place so the connector goes over its socket.
Conclusie
Calibrate your newly installed battery after completing this guide.
Nick Schultz
19.174 Reputatie
113 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.545 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 58
Altijd: 562
