Ga door naar hoofdinhoud
Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Turn off your laptop: stap 1, afbeelding 1 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Turn off your laptop: stap 1, afbeelding 2 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Turn off your laptop: stap 1, afbeelding 3 van 3
    • Shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
    • Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
  2. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the base cover screws: stap 2, afbeelding 1 van 1
    • Use a Phillips screwdriver to loosen the six captive screws securing the base cover.
  3. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the base cover's left side: stap 3, afbeelding 1 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the base cover's left side: stap 3, afbeelding 2 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the base cover's left side: stap 3, afbeelding 3 van 3
    • Press the tip of an opening pick into the seam between the base cover and the bottom-left corner of the frame (near the screen hinge).
    • It can be tricky to get the pick into the seam for the first time. Angle the pick vertically and press down with firm pressure.
    • Pivot the pick down and slide it around the corner to release the clips.
  4. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 4, afbeelding 3 van 3
    • Slide the opening pick along the left edge to release the clips securing the cover.
  5. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the base cover's right side: stap 5, afbeelding 1 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the base cover's right side: stap 5, afbeelding 2 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the base cover's right side: stap 5, afbeelding 3 van 3
    • Press the tip of an opening pick into the seam between the base cover and the bottom-right corner of the frame (near the screen hinge).
  6. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 6, afbeelding 1 van 2 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 6, afbeelding 2 van 2
    • Slide the opening pick along the right edge to release the clips securing the cover.
  7. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Remove the base cover: stap 7, afbeelding 1 van 2 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Remove the base cover: stap 7, afbeelding 2 van 2
    • Grasp the base cover along the screen hinge edge and pull up to loosen the cover.
  8. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 8, afbeelding 1 van 2 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 8, afbeelding 2 van 2
    • Lift and remove the base cover.
  9. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the battery screws: stap 9, afbeelding 1 van 1
    • Because of the battery connector's design, the only way to disconnect the battery is by physically removing it.
    • Use a Phillips screwdriver to loosen the six captive screws securing the battery.
  10. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Remove the battery: stap 10, afbeelding 1 van 2 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Remove the battery: stap 10, afbeelding 2 van 2
    • Grasp the top edge of the battery and lift to disconnect it.
    • You may feel a little resistance from the battery connector as it disconnects—that's normal.
  11. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 11, afbeelding 1 van 2 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 11, afbeelding 2 van 2
    • Lift and remove the battery.
  12. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Model differences: stap 12, afbeelding 1 van 1
    • The fans and heatsink assembly may look slightly different depending on the model. The procedure is nearly identical for both models—any differences will be noted in the relevant steps.
  13. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Disconnect the assembly: stap 13, afbeelding 1 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Disconnect the assembly: stap 13, afbeelding 2 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Disconnect the assembly: stap 13, afbeelding 3 van 3
  14. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 14, afbeelding 1 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 14, afbeelding 2 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 14, afbeelding 3 van 3
  15. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 15, afbeelding 1 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 15, afbeelding 2 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 15, afbeelding 3 van 3
    • Use a spudger or your fingers to gently guide the two thinner cables (black and yellow) out of their clips on the edge of the left fan.
    • During reassembly, route the two thinner cables and the thicker screen cable into their clips.
  16. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Detach the heatsink: stap 16, afbeelding 1 van 1
    • Use a Phillips screwdriver to loosen all captive screws securing the heatsink.
    • Depending on the model, your heatsink will have either three or five screws.
    • During reassembly, tighten the heatsink screws in ascending order based on the number stamped next to each screw.
  17. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 17, afbeelding 1 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 17, afbeelding 2 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 17, afbeelding 3 van 3
    • Insert the flat end of a spudger under the top edge of the heatsink and pry up to separate it.
    • Be very careful not to damage any surface-mounted components on the motherboard.
    • Continue prying up along the top edge to fully separate the heatsink.
  18. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 18, afbeelding 1 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 18, afbeelding 2 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 18, afbeelding 3 van 3
    • Grab the outer edges of the fans and remove the assembly.
  19. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Thermal paste application: stap 19, afbeelding 1 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Thermal paste application: stap 19, afbeelding 2 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Thermal paste application: stap 19, afbeelding 3 van 3
    • Reference our thermal paste guide for cleaning and application during the next two steps.
    • Remove all the old thermal paste and its residue from the motherboard:
    • The CPU and GPU have gray thermal paste on them.
    • Depending on the model, your laptop may only have a CPU.
    • The components around the CPU and GPU have a yellow, viscous thermal compound.
    • If you're reusing the heatsink and fan assembly, remove all the old thermal paste and compound from the corresponding spots on its underside.
    • Don't remove the small blue pads from the top edge.
  20. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 20, afbeelding 1 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 20, afbeelding 2 van 3 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 20, afbeelding 3 van 3
    • Apply new thermal paste to the CPU and GPU.
    • Apply a viscous thermal compound to the components around the CPU and GPU.
  21. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 21, afbeelding 1 van 2 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: stap 21, afbeelding 2 van 2
    • If you're reusing the assembly, you can skip this step.
    • If any of the small blue thermal pads stuck to the top edge of the heatsink, carefully remove and transfer them to their corresponding spots on the motherboard.
Conclusie
Spencer Day
95.703 Reputatie
662 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.540 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 75
Altijd: 512
