Lenovo N20p Chromebook Battery Replacement
Inleiding
Ga naar stap 1After a period of time or use, the battery may have issues and lose power after a charge. This guide will explain how to remove the battery from the Lenovo N20p Chromebook.
Wat je nodig hebt
Gereedschap
Toon meer…
Remove the two rubber feet of the back of the Chromebook using a metal spudger.
Remove six bottom 3.5 mm Phillips #0 screws and two top 5 mm Phillips #1 screws.
