Lenovo Legion Y530-15ICH Fan Replacement
Inleiding
Ga naar stap 1Replacing faulty fans is essential to keeping your computer’s insides working. This guide details how to remove the fans to either clean or replace them to ensure the processor does not overheat.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
Five 7mm screws
Two 6mm screws
Four 4mm screws
Use a JIS #1 screwdriver to loosen the five spring screws located at the middle of the fan piece.
Remove the plastic covering after the screws have been loosened.
6 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Thank you! Very clear and well photographed :)
Any recommended stores for the replacement fans?
Worked like a charm, thank you!!
where can i get a good replacement please
