Ga door naar hoofdinhoud
Lenovo Ideapad 320-15IAP Battery Replacement
Wat je nodig hebt
  1. Lenovo Ideapad 320-15IAP Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Lenovo Ideapad 320-15IAP Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back case.
  2. Lenovo Ideapad 320-15IAP Battery Replacement: stap 2, afbeelding 1 van 1
    • Pull the CD drive outwards with an opening tool until it pops out as shown. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Remove the CD drive.
  3. Lenovo Ideapad 320-15IAP Battery Replacement: stap 3, afbeelding 1 van 1
    • Lift up the cover using the opening tool on different spots along the side of the laptop.
  4. Lenovo Ideapad 320-15IAP Battery Replacement: stap 4, afbeelding 1 van 2 Lenovo Ideapad 320-15IAP Battery Replacement: stap 4, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver to unscrew the four 5.5 mm screws securing the battery.
  5. Lenovo Ideapad 320-15IAP Battery Replacement: stap 5, afbeelding 1 van 2 Lenovo Ideapad 320-15IAP Battery Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Ideapad 320-15IAP Battery Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery.
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 45
Altijd: 1,096
