Lenovo IdeaPad U530 Touch RAM Replacement
Inleiding
Ga naar stap 1This guide will show you how to remove the random access memory (RAM) in the Lenovo Ideapad U530 Touch.
RAM is a computer's short-term memory, which it uses to handle all active tasks and apps. None of your programs, files, games, or streams would work without RAM.
Ensure the device is unplugged and powered off; if possible, remove the battery before beginning disassembly.
Wat je nodig hebt
Remove the back panel by removing all screws. Use a PH000 screwdriver head.
Make sure to also remove the hinge screws.
Carefully pull on the tabs on each side of the RAM to release it from its slot
Carefully pull the old RAM out of the laptop.
