Ga door naar hoofdinhoud
Lenovo IdeaPad 330S RAM Replacement
Ilia Tocheny
Ilia Tocheny en een andere bijdrager
Voor het laatst geüpdatet op March 15, 2023
5 - 20 minuten
Gemiddeld
Door de gemeenschap gemaakte handleiding
You may find yourself in need of additional memory to feed hungry computer applications such as graphics and video editing tools. If you would like to replace a faulty RAM stick or one with insufficient capacity, follow this guide.
The battery for this device is not easily accessible and will require opening the device. Before you begin your replacement, be sure to disconnect the laptop from any power source. Additionally, we recommend that you turn off the device wait 5 minutes.
If you live in area rich of Static Electricity please advise using an ESD Strap.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Lenovo IdeaPad 330S RAM Replacement, Removing bottom case: stap 1, afbeelding 1 van 2 Lenovo IdeaPad 330S RAM Replacement, Removing bottom case: stap 1, afbeelding 2 van 2
    • Please turn off the laptop before opening the device
    • Remove the 10 screws as shown in the picture.
    • Gently using the tool pry off the bottom case
  2. Lenovo IdeaPad 330S RAM Replacement, Disconnecting Battery: stap 2, afbeelding 1 van 1
    • Using a spudger gently push the plastic connector to the left in order to disconnect the battery. wisdom here.
  3. Lenovo IdeaPad 330S RAM Replacement, Removing Black Case: stap 3, afbeelding 1 van 2 Lenovo IdeaPad 330S RAM Replacement, Removing Black Case: stap 3, afbeelding 2 van 2
    • Remove these screws as show in picture
    • Gently pry out the black case.
    • Note that one of the screws are Philips 2.5 and not Philips (the black screw top right ).
  4. Lenovo IdeaPad 330S RAM Replacement, Removing Ram Stick: stap 4, afbeelding 1 van 1
    • Gently using heavy duty spuder remove the old memory
  5. Lenovo IdeaPad 330S RAM Replacement, Installing Ram Stick: stap 5, afbeelding 1 van 1
    • Arrange the new ram stick accoring the pin on the motherboard
    • Push Gently on the stick until you hear two clicks
Conclusie
To reassemble the device, install your new stick(s) and follow these instructions in reverse order.
6 andere personen hebben deze handleiding voltooid.
Ilia Tocheny
1.640 Reputatie
9 handleidingen geschreven
8 opmerkingen
Is it possible to upgrade the cpu of my lenovo 330s which is a core i3 7gen to say a core i5 10th gen
Nathan D'souza - Antwoord
Only by replacement or the Motherboard…
The CPU is soldered to the M.B. and cannot upgraded easily
Ilia Tocheny - Antwoord
Hallo.
I am Japanese Hegt Stuident.
Do I need to remove the battery when removing the RAM?
(こんにちは。
日本の高校生です。
RAMを外すとき、バッテリーは外す必要がありますか?)
Muromi - Antwoord
You can disconnect the battery no need of removing it.
Ilia Tocheny -
I just Updated the repair guide of memory replacement.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 98
Altijd: 8,147
