Lenovo Edge 2-1580 Storage Replacement
Inleiding
Ga naar stap 1The guide will show you how to remove the storage hard drive unit that comes with the laptop. It is compatible with any 2.5" storage solutions like a SSD or HDD.
Wat je nodig hebt
Gereedschap
Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
5 andere personen hebben deze handleiding voltooid.
3 opmerkingen
The Edge 2 requires a hard drive of 7mm or less or the bottom cover will not fit properly.
Thank you, was looking everywhere to find that out!!!
Thank you, your help was so useful.
