Ga door naar hoofdinhoud
Lenovo 100s Chromebook-11IBY Battery Replacement
Wat je nodig hebt
  1. Lenovo 100s Chromebook-11IBY Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Battery Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Battery Replacement: stap 3, afbeelding 1 van 2 Lenovo 100s Chromebook-11IBY Battery Replacement: stap 3, afbeelding 2 van 2
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Battery Replacement: stap 4, afbeelding 1 van 2 Lenovo 100s Chromebook-11IBY Battery Replacement: stap 4, afbeelding 2 van 2
    • Unlock the keyboard ZIF connector to release the keyboard flex cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Unlock the touchpad ZIF connector to release the touchpad flex cable.
    • Carefully pull both flex cables out of the ZIF connectors.
    • Remove the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Battery Replacement: stap 5, afbeelding 1 van 1
    • Unplug the battery cable by pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo 100s Chromebook-11IBY Battery Replacement: stap 6, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to remove the three 6mm screws from the battery.
  7. Lenovo 100s Chromebook-11IBY Battery Replacement: stap 7, afbeelding 1 van 1
    • Remove the battery.
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
Milton Perez
630 Reputatie
5 handleidingen geschreven
USF Tampa, Team S7-G2, Cagle Spring 2017 Lid van USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 Lid
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 2,354
