Ga door naar hoofdinhoud
Lasko 4910 Filter Replacement
Julie Ling
Julie Ling en een andere bijdrager
Voor het laatst geüpdatet op December 14, 2018
10 minuten
Eenvoudig
If the filter in the fan is dirty and needs to be replaced, use this guide to learn how to dissemble the top part of the fan and replace your filter.
Wat je nodig hebt
Gereedschap
  1. Lasko 4910 Filter Replacement, Filter: stap 1, afbeelding 1 van 1
    • On the backside of the fan, remove the top two 4mm Phillips #Y1 screws using PH 1 bit and Magnetic Driver
  2. Lasko 4910 Filter Replacement: stap 2, afbeelding 1 van 1
    • Remove the top plastic portion of the fan
  3. Lasko 4910 Filter Replacement: stap 3, afbeelding 1 van 1
    • Remove all four 4mm screws using the Phillips #1 screwdriver.
  4. Lasko 4910 Filter Replacement: stap 4, afbeelding 1 van 1
    • Remove the filter from the fan.
Conclusie
Julie Ling
159 Reputatie
1 Handleiding geschreven
UC Davis, Team S11-G2, Lore Fall 2018 Lid van UC Davis, Team S11-G2, Lore Fall 2018
UCD-LORE-F18S11G2
4 Leden
1 handleiding geschreven
Één opmerking
Thank you for taking the time to do this. A great little guide for a fan that doesn't have a lot of support. Most details are looked over in online guide material. But this one was done with professional care.
Sincerely,
Davis Steffens
Seattle, WA
davissteffens@hotmail.com
PS: I Fix-It represents more than a company providing a service. I think you are reminding everyone that we have the right to Fix. Which in these weird times is a step needed.
Davis Steffens - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 1,716
