Ga door naar hoofdinhoud
Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement
Paige Guillory
Paige Guillory en een andere bijdrager
Voor het laatst geüpdatet op September 13, 2024
30 - 45 minuten
Eenvoudig
Uitgelichte studenten-handleiding
Use this guide to replace the hose on your Laila Ali Ionic Soft Bonnet Dryer (model number LADR560).
The hose transfers heat from the dryer to the soft bonnet. Tension from long-term use may cause the hose to disconnect from its heat source, which makes the dryer unusable.
If your hose disconnects from the air outlet, pushing the end of the hose inside the air outlet does not secure the hose in place. This may provide some heat to your hair, but a small amount of tension can pull the hose out of the device.
Replacing the hose ensures your dryer is functioning properly to provide the desired amount of heat to your hair.
Before beginning, disconnect the dryer from any external power source.
Wat je nodig hebt
Gereedschap
  1. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement, Hose: stap 1, afbeelding 1 van 1
    • Place the hair dryer on a sturdy surface with its backside facing up.
    • Using a Phillips #1 screwdriver, remove the six 12.7 mm screws from the back of the hair dryer.
  2. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 2, afbeelding 1 van 1
    • Open the hair dryer, and place the front cover to the side.
  3. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 3, afbeelding 1 van 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 3, afbeelding 2 van 2
    • Disconnect the clear tube from the hose cuff.
  4. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 4, afbeelding 1 van 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 4, afbeelding 2 van 2
    • Untwist the hose cuff off the fan opening.
  5. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 5, afbeelding 1 van 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 5, afbeelding 2 van 2
    • Pull the hose through the hose cuff until it reaches the top of the inner rim.
  6. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 6, afbeelding 1 van 1
    • Place and twist the hose cuff onto the fan opening.
  7. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 7, afbeelding 1 van 3 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 7, afbeelding 2 van 3 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 7, afbeelding 3 van 3
    • Slide the hose through the clear tube.
    • Slide the clear tube until it meets the rim of the hose cuff.
  8. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 8, afbeelding 1 van 1
    • Place the hair dryer's front cover on top of the back cover, leaving a finger's width space for the next step.
  9. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 9, afbeelding 1 van 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 9, afbeelding 2 van 2
    • Align the wire cover to the grooves of the left and right sides of the hair dryer.
    • Pull the cord through the wire opening.
    • Lightly press on the wire cover to secure its placement.
    • Push the front cover down to close the hair dryer.
  10. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 10, afbeelding 1 van 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 10, afbeelding 2 van 2
    • Carefully flip the hair dryer on its backside.
    • Place a screw in each opening, and screw them until secure.
  11. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: stap 11, afbeelding 1 van 1
    • Gently pull the hose to ensure it is secure.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
Please provide resource for purchasing a replacement bonnet for the Laila Ali LADR5604
Joyce Johnson - Antwoord
Can I purchase a bonnet replacement for MODEL: LADR5604WM?
Paula Tucker - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 958
