Ga door naar hoofdinhoud
LG V30 Plus Battery Replacement
Samuel Jahnke
Samuel Jahnke en een andere bijdrager
Voor het laatst geüpdatet op January 13, 2022
15 - 20 minuten
Gemiddeld
If your device isn’t turning on even after a charge, the battery may be faulty. Before you remove the battery, be advised that there may be a strong adhesive holding the battery with the phone. Use this guide to replace the battery in your device.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. LG V30 Plus Battery Replacement, Rear Glass: stap 1, afbeelding 1 van 1
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
  2. LG V30 Plus Battery Replacement: stap 2, afbeelding 1 van 2 LG V30 Plus Battery Replacement: stap 2, afbeelding 2 van 2
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
  3. LG V30 Plus Battery Replacement: stap 3, afbeelding 1 van 1
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
  4. LG V30 Plus Battery Replacement, Motherboard: stap 4, afbeelding 1 van 2 LG V30 Plus Battery Replacement, Motherboard: stap 4, afbeelding 2 van 2
    • Remove the ten 4mm screws using the Phillips #00 Screwdriver.
  5. LG V30 Plus Battery Replacement: stap 5, afbeelding 1 van 3 LG V30 Plus Battery Replacement: stap 5, afbeelding 2 van 3 LG V30 Plus Battery Replacement: stap 5, afbeelding 3 van 3
    • Gently push down on the small black tab with a Spudger to release the protective board.
    • Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
    • Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
  6. LG V30 Plus Battery Replacement: stap 6, afbeelding 1 van 2 LG V30 Plus Battery Replacement: stap 6, afbeelding 2 van 2
    • Slide an Opening Tool between the lower protective board and the phone to unclip.
    • Slide the tool along the remaining edges of the protective board until it pops off.
  7. LG V30 Plus Battery Replacement: stap 7, afbeelding 1 van 2 LG V30 Plus Battery Replacement: stap 7, afbeelding 2 van 2
    • Gently pry each visible ribbon cable away from the motherboard to disconnect them.
  8. LG V30 Plus Battery Replacement: stap 8, afbeelding 1 van 1
    • Gently remove the motherboard from the phone.
  9. LG V30 Plus Battery Replacement, Battery: stap 9, afbeelding 1 van 3 LG V30 Plus Battery Replacement, Battery: stap 9, afbeelding 2 van 3 LG V30 Plus Battery Replacement, Battery: stap 9, afbeelding 3 van 3
    • Use a Spudger to get between the battery and the phone and pry each edge of the battery away from the board.
    • There may be a strong adhesive under the battery, so work your way around the battery carefully and slowly.
    • Insert Opening Picks if needed to keep the battery elevated.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Samuel Jahnke
282 Reputatie
2 handleidingen geschreven
Cal Poly, Team S1-G3, Maness Spring 2019 Lid van Cal Poly, Team S1-G3, Maness Spring 2019
CPSU-MANESS-S19S1G3
4 Leden
10 handleidingen geschreven
Één opmerking
I did this and now my phone’s touch screen is unresponsive. The power button and volume buttons work and the phone turns on, but I cannot unlock my phone due to the touch screen not responding
Julian Marley - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 26
Altijd: 2,085
