Ga door naar hoofdinhoud
LG Refrigerator Freezer Ice Maker Replacement
Wat je nodig hebt
    1. LG Refrigerator Freezer Ice Maker Replacement, Unplug your refrigerator: stap 1, afbeelding 1 van 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      Vraag FixBot
      Voeg opmerking toe
    1. LG Refrigerator Freezer Ice Maker Replacement, Open the freezer door: stap 2, afbeelding 1 van 2 LG Refrigerator Freezer Ice Maker Replacement, Open the freezer door: stap 2, afbeelding 2 van 2
      • Pull open the freezer door fully.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: stap 3, afbeelding 1 van 3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: stap 3, afbeelding 2 van 3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: stap 3, afbeelding 3 van 3
      • Lift and remove the upper pull-out drawer.
      • Lift and remove the main drawer bin.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: stap 4, afbeelding 1 van 3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: stap 4, afbeelding 2 van 3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: stap 4, afbeelding 3 van 3
      • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
      • Lift the cover off of the rail and remove it.
      • Repeat this procedure for the left drawer rail cover.
      Vraag FixBot
      Voeg opmerking toe
    4. LG Refrigerator Freezer Ice Maker Replacement, Reassembly notes: stap 5, afbeelding 1 van 2 LG Refrigerator Freezer Ice Maker Replacement, Reassembly notes: stap 5, afbeelding 2 van 2
      • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
      • Hold the drawer rail cover flush against the side of the drawer rail.
      • You should feel the locking tabs protruding.
      • Push the rail cover straight downward to install. It should click into place.
      Vraag FixBot
      Voeg opmerking toe
    5. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer: stap 6, afbeelding 1 van 2 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer: stap 6, afbeelding 2 van 2
      • Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
      Vraag FixBot
      Voeg opmerking toe
    6. LG Refrigerator Freezer Ice Maker Replacement: stap 7, afbeelding 1 van 3 LG Refrigerator Freezer Ice Maker Replacement: stap 7, afbeelding 2 van 3 LG Refrigerator Freezer Ice Maker Replacement: stap 7, afbeelding 3 van 3
      • Lift the front of the drawer up.
      • Pull the drawer toward you to release the drawer from the drawer slides.
      • Remove the freezer drawer.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Refrigerator Freezer Ice Maker Replacement, Release the ice maker: stap 8, afbeelding 1 van 1
      • Use a Phillips screwdriver to remove the screws securing the ice maker to the top of the freezer compartment.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Refrigerator Freezer Ice Maker Replacement: stap 9, afbeelding 1 van 3 LG Refrigerator Freezer Ice Maker Replacement: stap 9, afbeelding 2 van 3 LG Refrigerator Freezer Ice Maker Replacement: stap 9, afbeelding 3 van 3
      • Insert a flat-blade screwdriver into the slot located on the right edge of the ice maker.
      • Pry outward with the screwdriver to release the locking tab securing the ice maker to the fridge.
      • When the tab releases, pull the right front corner of the ice maker down.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Refrigerator Freezer Ice Maker Replacement: stap 10, afbeelding 1 van 1
      • Repeat the previous operation on the left side of the ice maker to release it.
      Vraag FixBot
      Voeg opmerking toe
    4. LG Refrigerator Freezer Ice Maker Replacement: stap 11, afbeelding 1 van 3 LG Refrigerator Freezer Ice Maker Replacement: stap 11, afbeelding 2 van 3 LG Refrigerator Freezer Ice Maker Replacement: stap 11, afbeelding 3 van 3
      • Grasp the front edge of the ice maker and pull it towards you.
      • Lower the ice maker.
      Vraag FixBot
      Voeg opmerking toe
    5. LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: stap 12, afbeelding 1 van 3 LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: stap 12, afbeelding 2 van 3 LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: stap 12, afbeelding 3 van 3
      • Squeeze the ice maker connector to release it and pull it straight out to disconnect it.
      • Remove the ice maker.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
4 andere personen hebben deze handleiding voltooid.
Bill Gilbert
40.159 Reputatie
261 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
35.918 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 18
Afgelopen 7 dagen: 111
Afgelopen 30 dagen: 533
Altijd: 9,449
