Ga door naar hoofdinhoud
LG Optimus L7 P705 Display Replacement
Wat je nodig hebt
    1. LG Optimus L7 P705 Display Replacement, Display: stap 1, afbeelding 1 van 2 LG Optimus L7 P705 Display Replacement, Display: stap 1, afbeelding 2 van 2
      • Use a plastic opening tool to gently pry the back cover away from the phone by inserting it into the seam around the edges.
      • Once the cover is off, remove the battery and SIM card.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Optimus L7 P705 Display Replacement: stap 2, afbeelding 1 van 1
      • Using a Phillips #000 screwdriver, remove the twelve 3mm screws around the frame, including those near the SIM and SD card slots.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Optimus L7 P705 Display Replacement: stap 3, afbeelding 1 van 1
      • Carefully remove the bottom plastic plate located around the charging port area.
      Vraag FixBot
      Voeg opmerking toe
    4. LG Optimus L7 P705 Display Replacement: stap 4, afbeelding 1 van 2 LG Optimus L7 P705 Display Replacement: stap 4, afbeelding 2 van 2
      • Insert a plastic opening tool along the seam of the phone’s frame and gently apply pressure to lift off the midframe cover.
      Vraag FixBot
      Voeg opmerking toe
    5. LG Optimus L7 P705 Display Replacement: stap 5, afbeelding 1 van 2 LG Optimus L7 P705 Display Replacement: stap 5, afbeelding 2 van 2
      • Flip the phone over so the screen is facing up.
      • Carefully lift and remove the glass screen (display) from the front of the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
8 andere personen hebben deze handleiding voltooid.
Craig Lashley
307 Reputatie
1 Handleiding geschreven
USF Tampa, Team 9-1, Leahy Fall 2014 Lid van USF Tampa, Team 9-1, Leahy Fall 2014
USFT-LEAHY-F14S9G1
3 Leden
15 handleidingen geschreven
2Gids Commentaar
Great tutorial as always on ifixit. Just be mindful of the top clip holding the glass bevel as it can be tricky and is close to circuitry.
Sooty - Antwoord Deel
Im miles i great this ifixit i'm beginner
Omair Sarip - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 23
Altijd: 5,730
