Ga door naar hoofdinhoud
LG G6 Screen Replacement
Wat je nodig hebt
  1. LG G6 Screen Replacement, Rear Glass Panel: stap 1, afbeelding 1 van 3 LG G6 Screen Replacement, Rear Glass Panel: stap 1, afbeelding 2 van 3 LG G6 Screen Replacement, Rear Glass Panel: stap 1, afbeelding 3 van 3
    • In the following steps you'll be cutting through the adhesive that adheres the rear glass panel to the phone.
    • For reference, the backside of the panel is shown in the first photo. Note the clearance between the edge of the panel and the fragile ribbon cable beside the fingerprint sensor.
    • Be careful as you slice and pry to the left side of the fingerprint sensor, as seen from the outside of the phone in the third photo.
    • Inserting an opening tool more than 3 mm into the phone in this area can damage or tear the fingerprint sensor cable.
  2. LG G6 Screen Replacement: stap 2, afbeelding 1 van 1
    • Heating the backside of the G6 helps soften the adhesive securing the rear panel, making it easier to open.
    • Use a hairdryer, a heat gun, or prepare an iOpener and apply it to the lower edge of the G6 for about a minute to soften up the adhesive underneath the rear glass panel.
  3. LG G6 Screen Replacement: stap 3, afbeelding 1 van 2 LG G6 Screen Replacement: stap 3, afbeelding 2 van 2
    • Secure a suction cup to the rear panel, as close to the heated edge as possible.
  4. LG G6 Screen Replacement: stap 4, afbeelding 1 van 3 LG G6 Screen Replacement: stap 4, afbeelding 2 van 3 LG G6 Screen Replacement: stap 4, afbeelding 3 van 3
    • To make this step easier, you can prop up the heated edge of the phone on something that is about 0.5 inches (13 mm) thick, like an eraser. This will angle the phone so that the opening tool is easier to insert.
    • If you don't have a small object for propping, you can (carefully) perform this step at the edge of a desk or table to achieve the same angle of entry.
    • Lift the rear panel's bottom edge with your suction cup, opening a slight gap between the panel and the frame.
    • This may require a significant amount of force. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • Once you've created a gap, press the flat end of an opening tool into the gap.
    • The rear glass panel is fragile and can break if you use too much force or attempt to pry with metal tools.
  5. LG G6 Screen Replacement: stap 5, afbeelding 1 van 3 LG G6 Screen Replacement: stap 5, afbeelding 2 van 3 LG G6 Screen Replacement: stap 5, afbeelding 3 van 3
    • Slide the opening tool back and forth across the bottom edge of the phone, cutting through the adhesive securing the rear glass panel.
    • Once the adhesive is cut and the gap is wide enough, insert an opening pick into the gap to keep the adhesive from re-bonding. Remove the opening tool.
  6. LG G6 Screen Replacement: stap 6, afbeelding 1 van 3 LG G6 Screen Replacement: stap 6, afbeelding 2 van 3 LG G6 Screen Replacement: stap 6, afbeelding 3 van 3
    • As you proceed with separating the adhesive, you might need to re-apply heat to each edge before you can slice the adhesive securing it.
    • Additionally, you can use multiple opening picks for this process, leaving one in place on each side after you finish slicing to prevent the adhesive from re-adhering as it cools.
    • Slide the opening pick along the left edge of the phone to slice through the adhesive securing the rear panel.
  7. LG G6 Screen Replacement: stap 7, afbeelding 1 van 3 LG G6 Screen Replacement: stap 7, afbeelding 2 van 3 LG G6 Screen Replacement: stap 7, afbeelding 3 van 3
    • Re-insert the opening pick into the bottom edge of the phone and slide it up the right edge of the phone, cutting through the adhesive holding it in place.
  8. LG G6 Screen Replacement: stap 8, afbeelding 1 van 3 LG G6 Screen Replacement: stap 8, afbeelding 2 van 3 LG G6 Screen Replacement: stap 8, afbeelding 3 van 3
    • As seen in Step 1, the fingerprint reader cable runs to the left of the camera, fairly close to the edge of the phone. Be careful as you cut through the adhesive in the upper edges of the phone.
    • Carefully slide an opening pick across the top edge of the phone, separating the last of the adhesive securing the rear glass panel.
  9. LG G6 Screen Replacement: stap 9, afbeelding 1 van 3 LG G6 Screen Replacement: stap 9, afbeelding 2 van 3 LG G6 Screen Replacement: stap 9, afbeelding 3 van 3
    • Once all the adhesive is cut, use an opening pick to pry up the rear glass panel.
    • Remove the panel.
  10. LG G6 Screen Replacement: stap 10, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • If reusing the rear glass panel during reassembly:
    • Use tweezers to peel away any remaining adhesive from both the rear panel and the phone's chassis.
    • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Peel away the replacement adhesive's liner, align it with the back of the phone, and press it into place.
    • Remove any remaining liners, and replace the rear glass panel.
    • After installing the rear panel, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
    • You can also reinstall the rear panel without replacing the adhesive. Remove any large chunks of adhesive that might prevent the panel from sitting down flush. After installation, heat the panel and apply pressure to secure it. The phone won't be waterproof, but the residual adhesive is usually more than strong enough to hold.
  11. LG G6 Screen Replacement, Battery Disconnect: stap 11, afbeelding 1 van 2 LG G6 Screen Replacement, Battery Disconnect: stap 11, afbeelding 2 van 2
    • Remove the four Phillips screws holding down the lower antenna shield.
    • Bonus points: remove the illegal Warranty Void If Removed sticker.
  12. LG G6 Screen Replacement: stap 12, afbeelding 1 van 3 LG G6 Screen Replacement: stap 12, afbeelding 2 van 3 LG G6 Screen Replacement: stap 12, afbeelding 3 van 3
    • Insert the point of a spudger into the small gap between the lower antenna shield and the metal frame of the phone.
    • Gently pry up the antenna shield and remove it from the phone.
  13. LG G6 Screen Replacement: stap 13, afbeelding 1 van 1
    • Remove the seven Phillips screws holding down the upper antenna shield.
  14. LG G6 Screen Replacement: stap 14, afbeelding 1 van 3 LG G6 Screen Replacement: stap 14, afbeelding 2 van 3 LG G6 Screen Replacement: stap 14, afbeelding 3 van 3
    • Insert the flat end of a spudger into the small gap between the upper antenna shield and the phone chassis and pry up, releasing the clips holding the shield in place.
    • Remove the upper antenna shield and wireless charging coil.
  15. LG G6 Screen Replacement: stap 15, afbeelding 1 van 2 LG G6 Screen Replacement: stap 15, afbeelding 2 van 2
    • Use a spudger to pry up the press connector at the end of the battery's ribbon cable, disconnecting the battery.
  16. LG G6 Screen Replacement, Motherboard: stap 16, afbeelding 1 van 3 LG G6 Screen Replacement, Motherboard: stap 16, afbeelding 2 van 3 LG G6 Screen Replacement, Motherboard: stap 16, afbeelding 3 van 3
    • Insert a SIM removal tool or the SIM removal bit into the hole opposite the volume buttons and press to release the SIM/MicroSD card tray.
    • Remove the SIM/MicroSD tray.
    • Do not skip this step! The motherboard cannot be removed from the device without first removing the SIM/SD tray.
  17. LG G6 Screen Replacement: stap 17, afbeelding 1 van 2 LG G6 Screen Replacement: stap 17, afbeelding 2 van 2
    • Use the flat end of the spudger to lift up the two press connectors on the bottom end of the motherboard above the USB-C port.
  18. LG G6 Screen Replacement: stap 18, afbeelding 1 van 1
    • Remove the sticker connecting the motherboard to the vibration motor.
  19. LG G6 Screen Replacement: stap 19, afbeelding 1 van 3 LG G6 Screen Replacement: stap 19, afbeelding 2 van 3 LG G6 Screen Replacement: stap 19, afbeelding 3 van 3
    • Grab the motherboard by the top end (the end with the cameras) and gently lift it up and out of the phone.
  20. LG G6 Screen Replacement, USB-C Port: stap 20, afbeelding 1 van 3 LG G6 Screen Replacement, USB-C Port: stap 20, afbeelding 2 van 3 LG G6 Screen Replacement, USB-C Port: stap 20, afbeelding 3 van 3
    • Use the flat end of an opening tool to pry up the USB-C / mic assembly and remove it from the phone.
  21. LG G6 Screen Replacement, Screen: stap 21, afbeelding 1 van 3 LG G6 Screen Replacement, Screen: stap 21, afbeelding 2 van 3 LG G6 Screen Replacement, Screen: stap 21, afbeelding 3 van 3
    • In the following steps you'll be cutting through the adhesive that adheres the screen to the phone.
    • For reference, the back side of the screen is shown at left. Note the narrow clearance between the edge of the screen and the LCD underneath the glass.
    • If you plan to re-use your screen, be extra careful as you cut through the adhesive in the following steps.
  22. LG G6 Screen Replacement: stap 22, afbeelding 1 van 1
    • Heating the edges of the G6 screen helps soften the adhesive holding it place, making it easier to open.
    • Use a hairdryer, a heat gun, or prepare an iOpener and apply it to the lower edge of the screen (where the LG logo is) for about a minute.
  23. LG G6 Screen Replacement: stap 23, afbeelding 1 van 3 LG G6 Screen Replacement: stap 23, afbeelding 2 van 3 LG G6 Screen Replacement: stap 23, afbeelding 3 van 3
    • Place the flat end of an opening tool against the lower edge of the inside of the phone below the battery, as shown in the first photo.
    • Carefully apply pressure to the backside of the screen with the opening tool to create a gap between the screen and the body of the phone.
    • Separating the adhesive to create the initial gap may require some force. If you are unable to perform this step, reheat the lower edge of the phone to soften the adhesive and try again.
  24. LG G6 Screen Replacement: stap 24, afbeelding 1 van 3 LG G6 Screen Replacement: stap 24, afbeelding 2 van 3 LG G6 Screen Replacement: stap 24, afbeelding 3 van 3
    • Slide an opening pick back and forth across the bottom edge of the phone in the gap you created to cut the adhesive holding the screen in place.
    • If you plan to re-use this screen, be careful not to insert your opening pick more than 3 mm here to avoid damaging the LCD under the glass.
  25. LG G6 Screen Replacement: stap 25, afbeelding 1 van 3 LG G6 Screen Replacement: stap 25, afbeelding 2 van 3 LG G6 Screen Replacement: stap 25, afbeelding 3 van 3
    • Begin to make your way around the rest of the screen with your opening pick to separate the adhesive holding it in place.
    • If you plan to re-use this screen, be extra careful not to insert your pick more than 1 mm into the long edges of the phone to avoid damaging the LCD under the glass.
  26. LG G6 Screen Replacement: stap 26, afbeelding 1 van 2 LG G6 Screen Replacement: stap 26, afbeelding 2 van 2
    • As you proceed with separating the screen's adhesive, you might need to re-apply heat to each edge before you can slice the adhesive securing it.
    • Continue sliding your opening pick around the top edge of the phone.
  27. LG G6 Screen Replacement: stap 27, afbeelding 1 van 2 LG G6 Screen Replacement: stap 27, afbeelding 2 van 2
    • Slide your opening pick down the final long edge of the phone to separate the last of the adhesive holding the screen in place.
    • Don't try to remove the screen yet. The display cable is still adhered to the chassis from the other side of the phone.
  28. LG G6 Screen Replacement: stap 28, afbeelding 1 van 3 LG G6 Screen Replacement: stap 28, afbeelding 2 van 3 LG G6 Screen Replacement: stap 28, afbeelding 3 van 3
    • Slide an opening pick under the display cable to separate the adhesive holding it in place.
  29. LG G6 Screen Replacement: stap 29, afbeelding 1 van 3 LG G6 Screen Replacement: stap 29, afbeelding 2 van 3 LG G6 Screen Replacement: stap 29, afbeelding 3 van 3
    • Carefully lift up the screen, starting at the top edge (where the front-facing camera lives) making sure to pull the display cable through its slot in the chassis.
    • Remove the screen.
    • Before you install your new screen, clean all traces of adhesive from the phone frame to help the new adhesive bond properly. You can use high concentration isopropyl alcohol to help with any tough spots.
Conclusie
18 andere personen hebben deze handleiding voltooid.
Taylor Dixon
71.818 Reputatie
94 handleidingen geschreven
2Gids Commentaar
Como puedo reutilizar la pantalla?
Roosvelt Quiñones - Antwoord
Did a combination of a screen replacement and back glass replacement. Great guides and easy to follow. However, I ordered a front screen from ifixit.com and received a screen that was already attached to the frame part, so I still had to figure out how to get some other parts like the speaker, heat sink, and other little parts and transfer them to the new frame.
Aaron Dimatulac - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 91
Altijd: 25,848
