Ga door naar hoofdinhoud
LG G2 mini LTE Rear Facing Camera Replacement
Nicholas Van Beek
Nicholas Van Beek en 2 andere bijdragers
Voor het laatst geüpdatet op November 29, 2021
30 minuten
Gemiddeld
Betere introductie
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
iFixit krijgt commissie als je dingen koopt via deze links.
  1. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Battery Cover: stap 1, afbeelding 1 van 1
    • Remove the back cover by placing your fingernail in the crease between the cover and the charging port.
    • Pry upward and the cover should pop off easily.
  2. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Battery: stap 2, afbeelding 1 van 1
    • Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay.
  3. LG G2 mini LTE Rear Facing Camera Replacement, Unscrew the Motherboard Cover: stap 3, afbeelding 1 van 2 LG G2 mini LTE Rear Facing Camera Replacement, Unscrew the Motherboard Cover: stap 3, afbeelding 2 van 2
    • Locate 10 screws and remove each one using a screw driver.
  4. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Motherboard Cover: stap 4, afbeelding 1 van 1
    • Use a plastic spudger tool to pry away the cover by placing it between the cover and the screen bezel.
    • Pry all the way around the phone about every centimeter until the cover is completely separated from the phone.
  5. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Camera: stap 5, afbeelding 1 van 3 LG G2 mini LTE Rear Facing Camera Replacement, Remove the Camera: stap 5, afbeelding 2 van 3 LG G2 mini LTE Rear Facing Camera Replacement, Remove the Camera: stap 5, afbeelding 3 van 3
    • Locate the rear facing camera.
    • Pry the ribbon cable off of it's connector using the plastic spudger tool.
    • Use your finger to remove the camera.
Conclusie
Nicholas Van Beek
593 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 1-9, Shastany Fall 2014 Lid van UMass Dartmouth, Team 1-9, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G9
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 1,698
